RB Presilencer actuating 6 ports
Old Mar 17, 2001 | 06:56 AM
RXster's Avatar
Question RB Presilencer actuating 6 ports
1990 NA
I just purchased a used RB header and presilencer (with tube to actuate 6 ports / 6PI)
A blank off cover was provided for the ACV and from what I’ve read most people remove this and the air pump which operates the 6 ports for my year. According to my manual it also supplies pressure to the VDI.
1. Is this the preferred method, or should I leave my air pump actuation?
2. Anything else affected if I remove it?
3. Will I get a computer error if I remove all this stuff?
4. Will the 6PI open at the right time using pressure from the presilencer? Anyone check the actual opening RPM compared to the air pump?
5. No fittings were included to get from the presilencer to the 6PI or VDI. How do you guys connect to the presilencer tube flange---a barb fitting to vacuum hose maybe? I assume you run a vacuum line directly to the solenoid valves for both the VDI and 6PI, correct?
THANKS!
90 NA Vert w/ TII hood & Kaminari kit
RB header / presilencer
SC soon!
Wanted: Greddy or HKS cat back
Old May 23, 2001 | 04:00 PM
RXster's Avatar
Response from Mazdatrix on the subject after I inquired about how much pressure the RB presilencer tube will supply. It looks like it will work, so I can lose my air pump and ACV! According to the manual, I need 1.4psi to fully open the 6PI and 2.8psi to open the VDI. I can always bleed off a little pressure if it opens too early.
Subj: Re: RB presilencer tech question
Date: 5/23/01
Yes, the tube will work, but the 6-ports, and the VDI will probably open a
little early. The tube should produce about 4psi at 4000 rpm. (Approx.)
90 NA Vert w/ TII hood & Kaminari kit, K&N intake, RB header / presilencer, HKS 60mm catback, custom cold air box, custom FTP air inlet vents, KSP headlight vent, modified TB, SS oil cooler hoses, OMP kit from http://ahura.iwarp.com/2strokepump.htm, 140K miles & new paint, may add an SC whenever Mariah gets their act together.
24seven_dada
20
Nov 10, 2018 12:03 PM
alexdimen
20
Oct 23, 2015 01:50 PM
jeremyferguson4444
Sep 19, 2015 01:27 PM
doritoloco
Sep 5, 2015 12:41 PM
