Megasquirt trouble when starting HOT
Old Oct 21, 2007 | 08:24 PM
AlexG13B's Avatar
brap brap brap
i seem to have a problem when trying to crank the car over at about 200*F-210F (according to tempature on Megatune)- btw new coolant temp sensor was replaced today.
it seems to crank and not wanna turn on till tempature lowers to below 200*F mark.
also on Megatune tach rpms never really go above 180RPMS when cranking. grounds were cleaned today and tightened, not sure what really is going on.
any ideas?
Old Oct 22, 2007 | 01:38 AM
Jobro's Avatar
SAE Junkie
My car reliably starts at 160rpm
Old Oct 22, 2007 | 04:17 AM
H4Inf's Avatar
If you use flood clear mode (foot to the floor while cranking) does that help it start?
If it does then that would indicate that it's probably too rich on hot start. If not, then probably too lean.
This is configurable under Startup/Idle - Cranking Pulsewidth (on MS2Extra).
Mine looks like this:
Paul.
Old Oct 22, 2007 | 05:55 AM
AlexG13B's Avatar
brap brap brap
no flood clear doesnt help much.any other ideas?
Old Oct 22, 2007 | 06:06 AM
H4Inf's Avatar
Since Jobro's car starts ~160rpm then it has got to be something else.
The plugs arent fouled are they, or the wrong type/heat rating?
If they are fine, then it's simple got to be too lean for hot starts.. which is configurable as i said above...
What do you think?
Old Oct 22, 2007 | 08:05 AM
AlexG13B's Avatar
brap brap brap
brand new stock ngk plugs installed 3 days ago. somtimes rpms on megatune tach drops to 58rpms, but engine is actually cranking higher from what i can hear.
mine is setup with injector PW and not %. so its kinda confusing to compare yours to mine.
Old Oct 22, 2007 | 08:25 AM
renns's Avatar
Try turning the cycling the key to run position a couple times before attempting a hot start. It's possible you've got vapour lock problems, and a few pump priming cycles will purge the vapour and properly pressurize the rail. If that helps with startup, then you may have issues with a leaking fuel pump check valve. The stock Mazda efi setup runs the fuel system at higher pressure at hot start by venting the fuel pressure regulator reference line to atmosphere via a solenoid valve. This is likely to address similar problems.
Old Oct 23, 2007 | 12:14 AM
AlexG13B's Avatar
brap brap brap
well today it wouldnt start at cold. tach on megatune wouldnt even cap 150RPMS. the lights onthe megasquirt would flash sometimes, the only way i was able to start it was push starting it and it stayed on.
Old Oct 23, 2007 | 03:51 AM
H4Inf's Avatar
is the power feed to the megasquirt fresh from the battery? when cranking with a laptop plugged in is it saying it resets at all, and can you check battery voltage on the mega as well?
Old Oct 23, 2007 | 05:47 AM
AlexG13B's Avatar
brap brap brap
no it doesnt say its reseting, just either showslow cranking rpms or none at all. had to push start it to get it going. i had jumper cables on it as well while trying to crank it.
Old Oct 23, 2007 | 08:53 AM
muythaibxr's Avatar
MegaSquirt Mod
that means you have some noise most likely.
Are you running single or dual trigger?
Ken
Old Oct 23, 2007 | 05:39 PM
AlexG13B's Avatar
brap brap brap
idk its the plug n play unit from 1st batch.
Old Oct 24, 2007 | 09:39 AM
AlexG13B's Avatar
brap brap brap
here is the log, mind you the engine itself was cranking constantly
File Type: zip
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
