Microtech Just got a LT8
Old Oct 20, 2007 | 01:45 AM
TurboMazdaSpeed's Avatar
1.3L piston eater
Just got a LT8
just picked it up yesterday its out of my my friends rx7, any suggestions or tips for installing ?
Old Oct 20, 2007 | 01:17 PM
88t2romad's Avatar
(_8(|)
Do it right do it once! Do you have the install manual?
Old Oct 20, 2007 | 06:23 PM
1.3L piston eater
good advice, noi dont.. ill have to grab it off my friend i hope he still has it, i havent installed it yet got a link to a online manual if there is one?
Old Oct 22, 2007 | 10:28 PM
88t2romad's Avatar
(_8(|)
https://www.rx7club.com/microtech-111/microtech-software-windows-vista-whats-compatible-693275/
Old Oct 22, 2007 | 11:07 PM
1.3L piston eater
thanks! i clicked on LT8 manual and "MT10" showed up is it the same thing? or a glitch or somthing
Old Oct 23, 2007 | 10:38 PM
88t2romad's Avatar
(_8(|)
you downloaded the 6.32 mb file under the software page???
Old Nov 20, 2007 | 05:10 PM
1.3L piston eater
ok well i got the whole microtech installed, everything perfect. no vac or fuel leaks , go to start it up and nothing. just cranks, running too rich you think or too lean? running a walbro 255 pump with 550 primaries and 800cc secondaries and when i turn the key before crankin i can just hear the fuel pouring into the engine lol
Old Nov 20, 2007 | 09:46 PM
88t2romad's Avatar
(_8(|)
what engine was it on, and what engine did it go onto? What was it programmed for? (injector sizes)
Old Nov 20, 2007 | 10:34 PM
1.3L piston eater
programmed for the injectors that i have (took them off the same car i got the microtech from) it was on a S4 with S5 internals, same ports. (stock)
Old Nov 22, 2007 | 10:26 PM
1.3L piston eater
bump i need to get this thing started..
getting fuel : yes
getting spark: yes
microtech working/wired properly: yes
i smell gas after cranking, no poppin or signs of starting, engine seems to be turning over slower then usual.. recharged battery and it still wont start, i tryed de-flooding it and nothing, swapped out the spark plugs for brand new NGK-R's (made sure they are the right ones) blah blah.. ideas?
Old Nov 28, 2007 | 02:35 AM
myfc3s's Avatar
That's what she said...
Double check how you wired your coil packs.
Old Nov 28, 2007 | 03:37 AM
1.3L piston eater
got it started!!! was extremely flooded/ wouldnt idle.. tuned it abitnow it runs,but wont rev past 3k just hardcore bogs! already switched secondary injector plugsand that wasnt it. think it may just need a tune?
Old Nov 28, 2007 | 04:56 PM
rx72c's Avatar
Top Answer: 1
Do you know your way around a handset well?
it sounds like your staging is way out.
Old Nov 28, 2007 | 05:08 PM
1.3L piston eater
no i dont.. a friend has one though, hes not a master tuner or anything but hes the one who got the car started with the handset (he may have accidently messed the staging up while trying to get the car started)
Old Nov 28, 2007 | 06:45 PM
rx72c's Avatar
Top Answer: 1
well if your mate knows how to setup staging.
put these numbers in.
Map_stg 02HG
Rev_stg 2000rpm
Opt_stg 50%
And then go to the load map and put in Load_00HG 4.76. see what happens.
Old Nov 28, 2007 | 07:38 PM
1.3L piston eater
alright ill give that a shot next time i catch him off work ! thanks alot!!!
Old Nov 30, 2007 | 12:39 AM
myfc3s's Avatar
Glad to know you got it to fire up. Also do you have a laptop? see where your timing is at.
Old Dec 1, 2007 | 02:02 AM
1.3L piston eater
k we tryed the staging thing and nothing. not quite sure what it is, will have to take it to a certified microtech tuner. there are only 2 in town here that i know of , i may get it dynotuned depending on how much it will cost, so ill get back to ya guys later!!
Old Dec 1, 2007 | 02:49 PM
rx72c's Avatar
Top Answer: 1
it sounds like its running really rich and its killed the spark plugs. put another set of plugs in their.
go to the opt_mixtrm and turn it down 10%.
Old Dec 1, 2007 | 03:14 PM
1.3L piston eater
hmm you may be right but i hope your not.. they are brand spankin new!!!!!!! it is running very damn rich (according to my narrowband) it just snowed alot (figures) so i wont be doing it today.
Old Dec 1, 2007 | 07:48 PM
rx72c's Avatar
Top Answer: 1
Yes they are new. BUt they are very easy to wreck. just simply by running them rich you can kill them.
Old Dec 21, 2007 | 01:41 AM
1.3L piston eater
HAHAAHA.. well... FINALLY FINALLY found out the problem.. damn microtech ECU is fucked... internally, where the harness plugs in, brang it to forcefed perfomance , they wiggled the harness a bit while i reved it and boom revs smooth as butter.. gota send the bitch back to microtech to get it repaired now that should cost me a pretty penny.. my advice NEVER ****** BUY USED MICROTECHS!!!!! even if its from your friend!
Old Dec 21, 2007 | 06:41 AM
rx72c's Avatar
Top Answer: 1
These things only happen when they are installed incorrectly. And it seems. MOST ARE.
Old Dec 21, 2007 | 04:25 PM
1.3L piston eater
what do you mean? it was installed flawlessly... plus i never dropped the ECU or dropped anything on it, etc etc. it was installed by sombody who knows rx7s inside out. im sure my friend didnt knowingly sell it to me when it was like this, but his engine did blow before he sold it
Old Dec 21, 2007 | 04:45 PM
rx72c's Avatar
Top Answer: 1
Look im sorry to disappoint you but none of the rx7s i have done installations on have ever experienced any wiring/computer problems cause i know how to do an install that is going to be reliable.
Some wiring can look pretty but completely rubbish from the inside, and it means nothing if its installed by someone who knows rx7s inside out, it dosnt mean its good.
And for all you know, it could have been the previous install.
So how do you know its not the loom?
