West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Need help to Hook Up Battery Harness
Old Oct 17, 2007 | 06:56 PM
FCFreakman's Avatar
HEY. Does anyone have exp on hooking up the battery wiring harness on FC? Thanks
Old Oct 18, 2007 | 06:56 PM
mazpower's Avatar
Slizzard sippin sizzurp
The positive cable goes straight to the starter + terminal and a branch of that goes into the fuse block in the engine bay. Negative goes to ground. Are the wires still there or are you going to run them new?
Old Oct 19, 2007 | 01:38 AM
Carzy Driver's Avatar
Law Breaker
make sure you get the reverse sensor and 5th gear indicator plugs right. other than that it's easy.
sinclair7seven
11
Sep 11, 2015 10:15 AM
windom
Sep 11, 2015 04:48 AM
