50/50 coolant?
Old Apr 9, 2002 | 10:39 PM
MazdaRx7Power's Avatar
50/50 coolant?
if lets say i have 80% water and 20% coolant in my system. would the temp get so hot that it would boil the water but the temp stay the same. cause i'm having this problem were the temp rises and goes back down. when i check the coolant all i hear is alot of air and the coolant just drops to the bottom of the radiator. is it possible that i have 2 much water and no enough coolant and the water is filling the system up with air????
Old Apr 9, 2002 | 10:43 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
when my thermostat went, and i had ltos of air in my system (and still do, causing me props today) i hurd a gurgling sound like it was boilng
Old Apr 9, 2002 | 10:49 PM
NZConvertible's Avatar
I'm a boost creep...
I'm really not sure what you're trying to say, but whatever your problem is, it has nothing to do with your coolant mix. If you have air in the system it needs to be bled out. From cold, run the engine with the radiator cap off and the heater on. Run it until it's warmed up and there are no bubble appearing in the filler neck.
NEVER run anything less than a 50/50 mix of water and coolant. It's the corrosion inhibitors in the coolant that are vitally important to your engine.
Old Apr 9, 2002 | 10:52 PM
Icemark's Avatar
Sounds to me like the water pump or thermostat has rotted with that mix of water and coolant.
Old Apr 9, 2002 | 11:03 PM
well the waterpump was put on about 6 months ago
LongDuck
Oct 7, 2015 08:12 PM
musker
Oct 1, 2015 05:58 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
