Power FC Air Pump Control With PFC
Old Oct 9, 2007 | 07:58 PM
I have removed all emission items except for the air pump and was wondering what do I need to add or change in order to get the air pump to work with the PFC? Do I wire in a 9v trip relay connected to the fuel pump idle resistor or do I add a few resistors to some of the emissions control wiring in order to trick the ecu into thinking the control valves are still in place?
Chuck, please provide your all knowing guidance.
Setup:
GZ LIM
Completely custom wiring
Relocated Air Pump with air line directly connected to the Cat.
etc.
Attached Thumbnails Air Pump Control With PFC-dsc06802.jpg   Air Pump Control With PFC-dsc04639.jpg   Air Pump Control With PFC-dsc07007.jpg   Air Pump Control With PFC-dsc06831.jpg   Air Pump Control With PFC-dsc06833.jpg
Old Oct 9, 2007 | 08:53 PM
cewrx7r1's Avatar
Eye In The Sky
All you have to do is turn off the O2 FB control so it does not try to go close loop.
The air pump will work as is.
I am singlel turbo without any emmisions control except the air pump is hooked up as normal and it's output goes directly to my MP or cat when it is installed.
No special wiring required except the normal air pump wiring.
Old Oct 10, 2007 | 01:12 PM
Thank you sir!
Old Mar 3, 2014 | 12:24 PM
p00shy's Avatar
So the Airpump will work with the PowerFC? i just need to close the 02 feedback?
Old Mar 3, 2014 | 12:34 PM
p00shy's Avatar
I followed the writeup on how to install the PFC and cut the emissions on the wireharness. i would still like to use the Air pump so i plan on reconnecting that wire as i would still like to run the cat.
Is there anything special that needs to be done or just reconnect that wire and im good to go?
Thanks
Old Mar 14, 2014 | 11:27 AM
cewrx7r1's Avatar
Eye In The Sky
The air pump can work without the cat or O2 sensor just to add more air to the exhaust to help burn up more hydrocarbons.
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
