What clutch for ~450-500 hp
Old Oct 7, 2007 | 11:58 AM
mykah89's Avatar
Just as stated, im going to be in the area of 450 500 max come next year and im in the process of having my tranny freshened up so i figured i might as well replace the clutch. So was i was thinking the ACT street/strip clutch but i am not married to it.. i dont really plan on taking my car to the track much or at all but i do like my spirited driving. Any recommendations ?
Old Oct 7, 2007 | 12:01 PM
PvillKnight7's Avatar
clutchnet.com sprung 6 puck
Old Oct 7, 2007 | 12:29 PM
EZFD's Avatar
so far i've had great luck with the Spec Stage 3.
Old Oct 7, 2007 | 01:31 PM
Erdin's Avatar
Water Injection Specialist
I was runing 465 at the hub with the Spec stage 3+ and it drove like a every day car no problems.
Old Oct 7, 2007 | 01:44 PM
mykah89's Avatar
Great i guess i will look into the spec stage 3 clutch then,, also sorry this is a little off my original topic, but when i dropped my transmission the other day.. (take not everything on the car i got was half assed) I think i am missing some things.. im not sure how to explain it and maybe i can get pictures later.. anychance anyone would have a picture of the under side of their car so i can use it as a reference.. thanks again
Also when taking my exhaust off i was inspecting and it was a Trust exhaust and it had a couple slash type symbols,i searched but couldnt find too much information is this any good or should i look into something else, im running a T78 turbo with a street ported motor. Just trying to figure out exactly what i have and what i need to get everything together.
Old Oct 7, 2007 | 03:07 PM
signofinfinity's Avatar
Coyote
ACT 6puck Xtreme Pressure Plate un Sprung.
Call Jason at rx7 Store.net
G
Old Oct 8, 2007 | 08:30 PM
mykah89's Avatar
I just found out my car has a centerforce dual friction clutch,, is that ok or should i look into changing and upgrading anyways... thanks
Old Oct 8, 2007 | 09:11 PM
justturbo2's Avatar
Registered User
it would probably hold for alittle bit, depending on driving habit. i would put some money aside for a new clutch. good luck
Old Oct 8, 2007 | 11:18 PM
sk8world's Avatar
Chasing numbers
500+ for me on this one..
Old Oct 9, 2007 | 01:51 AM
A7X's Avatar
A7X
For sale!! PM
G
right on bro
Old Dec 11, 2007 | 01:10 PM
sk8world's Avatar
Chasing numbers
take it back. Clutch wont hold 500+ !! I have less than 3k on it, no drag racing either. Just got it dialed in within the last 2 months. Kinda pissed as spec told me it would hold 500lbs of torque!
Old Dec 11, 2007 | 01:41 PM
0110-M-P's Avatar
Too Many Projects
At the engine, but not at the wheels.
Old Dec 11, 2007 | 07:45 PM
sk8world's Avatar
Chasing numbers
wheels!!
Old Dec 11, 2007 | 08:33 PM
6 puck. [/endthread]
Old Dec 12, 2007 | 09:40 AM
0110-M-P's Avatar
Too Many Projects
wheels!!
Well when a clutch company says a clutch will hold x-amount of torque it means at the clutch itself, not the wheels. They don't know exactly what your drivetrain losses are going to be and therefore cannot speculate to what the clutch will hold at the wheels in a specific car. At rx7store it says the clutch has a torque capacity of 520 ft.lbs. This would only be 442 rwhp if you guessed at a 15% drivetrain loss.
Old Dec 12, 2007 | 12:18 PM
rotaryengineering's Avatar
Buy a Mcleod Clutch
All the really fast cars run these clutches and they are well worth the cost.
Good Luck.
Old Dec 12, 2007 | 01:02 PM
A-Spec Tuning's Avatar
Registered User
wheels!!
They may have told you that but you were mis-informed. When I spoke to Spec regarding these clutches, we specifically went over the flywheel vs. RWHP issue. They say that all their measurement are at the flywheel. Therefore, the Spec stg. 3+ is rated at 598 FLYWHEEL TRQ. Just wanted to help clarify things for you guys
Old Dec 12, 2007 | 09:48 PM
LETHAL RX7's Avatar
I have a cintered iron clutch disc that will hold whatever you wanna throw at it.. its a bit of a pain to drive with though..
Greg
Old Dec 12, 2007 | 11:34 PM
skir2222's Avatar
I win
If your going 6 puck, get a sprung. It will help in drivetrain shock, your rear might thank you.
Old Dec 17, 2007 | 01:24 PM
Rx-7Addict's Avatar
Rotary Powered
whoever said ACT street strip... NOOOO
I have one and it does not hold up to my 420whp . the clutch is basically shot and I am looking to get a beefier clutch. Street / strip lasted less than 10k miles
Snoopy FD
Oct 13, 2016 06:12 AM
risingsunroof82
Sep 9, 2015 08:06 PM
