what is biggest tires can i put?
Old Oct 7, 2007 | 04:45 AM
v8huntr's Avatar
Hello,
I have 95fd and thinking about getting set of wheels and tires for track use. what do you guys think of enkei rpf1. can i run 9.5inch wheels in front? I would like to use same size tires all around if it is possible. i was thinking 275s all around.
thanks
Old Oct 8, 2007 | 05:11 PM
RISEN's Avatar
Sure, if you can get 50/51mm offset up front
Old Oct 8, 2007 | 08:27 PM
Jaiyurai's Avatar
Endure Persevere Succeed
Get the Enkei RPF1 17x9.5 +38 offset. Front and Rear. You should be fine.
Old Oct 9, 2007 | 01:17 AM
mcfly's Avatar
we just put a 18x10 +20 on the back of a fd with 275's.
zip tie tight, could have rolled the gaurd a bit more but no need.
Old Oct 9, 2007 | 09:13 AM
owen is fat's Avatar
a lot of people run 18x10 so they can use the 285/30R18 tire that has a very short overall diameter and gives great clearance because it is shorterthan the common 275/35R17 size for 17x10.
Old Oct 9, 2007 | 06:07 PM
gnx7's Avatar
The Enkei is a nice wheel; however it won't maximize the tire potential you can stuff in there as the offset isn't perfect.
Spend the extra money and get 18x10 +50mm offset CCW classic wheels. They are a quality 3 piece wheel and will allow 285/30/18's all around with coilovers. They are also very light being around 20lbs each.
CCW's new are around $2200 for the set (4). You can buy used (1 weekend takeoffs) Hoosier or other race tires from Bob Chick Used race tires for around $70/each in just about any size.
If you don't have big brakes on the car now would be a good time to get them.
Old Oct 9, 2007 | 10:34 PM
v8huntr's Avatar
2200 is quite more than enkei's. enkei rpf1s are 320 each compare to 550.
Th0m4s
Feb 26, 2019 02:04 AM
Skeese
65
Mar 28, 2017 03:30 PM
