Power FC high duty cycles!
Old Apr 9, 2002 | 09:45 AM
matty's Avatar
high duty cycles!
If i get higher boost due to cooler weather i am seeing 93-94% duty cylces..this scares me! What can i do to run say 13psi and lower thhe injector duty cycle. Can i upgrade the fuel pump or do i upgrade injectors? if i run bigger injectors do i need to upgrade the primary, secondary or both? I really do not want to upgrade the injectors till i get an IC. Currently moy mods are full exhaust, cold air intake, and power fc.
Thanks.
Matt
Old Apr 9, 2002 | 11:05 AM
cewrx7r1's Avatar
Eye In The Sky
Run a search, this has been talked about much on this forum.
You only need a bigger fuel pump if the pressure is dropping due to the volume of fuel being consumed.
The same principles apply to carbs as fuel injection.
Old Apr 9, 2002 | 11:10 AM
matty's Avatar
i have seen this topic discussed but not how to correct it....i will do a search too.
Andrew7dg
Aug 6, 2017 01:41 PM
Einheri
Oct 7, 2015 12:23 PM
