Any experience with these wheels?
Old Apr 9, 2002 | 12:02 AM
martini's Avatar
They are called RPMs made by Centerline. They are one piece, forged, and really lightweight. I saw an ad in some magazine that said an 18" was only 13.5lbs. (not sure about width, but I would assume maybe 8")
They come in Gold, White, Silver, and "Black Pearl".
Anyone have any experience with them? It seems a little too good to be true. They aren't exactly the best looking rims, but they are decent..and for that weight, I'm willing to sacrifice a little looks..
Old Apr 9, 2002 | 12:36 AM
maxcooper's Avatar
WWFSMD
I was pretty excited when I saw the ad, too, but it turns out they are only available in pretty narrow widths.
http://www.centerlinewheels.com/w_catalog/fwd.html
It says the available sizes are 17x7, 18x7.5 and 19x7.5
Still, I hope it is an indicator that the "light wheel" market segment is strengthening. It seems like 40 lbs chrome wheels have had the popular spotlight for a while. I am sure that will continue, but a new line of forged wheels from a company with a good advertising budget should at least generate some excitement about lightweight, strong wheels. Hopefully that will result in more selection and better prices overall.
-Max
Old Apr 9, 2002 | 02:09 AM
krzyxrevver12's Avatar
looks kinda like the audi s4 stock wheel
Old Apr 9, 2002 | 05:31 AM
SleepR1's Avatar
Yeah, the least expensive strong, lightweight wheels that you'll find for the FD with aggressive widths are the SSR Integral A2s in 9 x 17 with 45-mm offsets. They're on special at Tire Rack for $289 each. SSR is discontinuing the Integral A2, which is the reason for the great pricing. I have a set of 5 myself (full-size spare) with 255/40-17 Yokohama AVS Intermediates. The total weight with brand new tires mounted was 45-lbs each. Figure 27 lbs for the tire, that leaves 18 lbs for the SSR Intergral 9 x 17 wheel weight, which is in line with what Tire Rack advertises the IA2's weight as in this size--between 17 and 18 lbs.
Do a wheel search at Tire Rack's website to check their inventory on this size. Make sure you get the rear wheel fitments, as their front wheel fitment is 8 x 17 either 38-mm or 45-mm offset, with 235/45-17...which is a bit tall, and narrower. The 9 x 17, 45-mm work all the way around with 255/40-17 Yokohama AVS Is. If you're not sure about clearance get 245/40-17 Pirelli P-Zeros. These are slightly narrower and shorter than the 255/40-17 Yokos.
http://www.tirerack.com/wheels/index.jsp
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
Marty RE
Aug 17, 2015 09:36 AM
