Microtech wideband woes...
Old Sep 15, 2007 | 06:30 PM
dean23's Avatar
pwned
wideband woes...
i did do a bit of earching on the AEM today, but didnt find anything i didnt know yet..
heres my problem.
i am using the AEM UEGO wideband. Awesome wideband IMO, but im having a bit of difficulty getting it connected to my mircotech. i have an LT8 (might be LT8X or something like that)
theres a way to switch the wideband OUTPUTS between the 0-5v, 1v-2v, and thene theres an Autotonic something output thats between 0-1V and the Nernst (non linear) output thats 0-1v.
now i know that since the LT8 only reads narrowband, my only options are the nernst (witch from my understanding is a "normal" narrowband) and the autotronic output, which i have no idea what it is.
i tried the nernst output with no success. it was the same for the autotronic. im beginning to believe theres something wrong with the 02 senser input, but i would liek to hope not.
has any1 else had this issue with theyre widebands? any tips? all my connections are good... i soldered the wires and wrapped them with elect. tape.
Old Sep 16, 2007 | 10:01 AM
Aaron Cake's Avatar
Engine, Not Motor
You can test the Mircotech's narrowband input easily by swapping on a narrowband sensor. Or if you don't want to run the car, connect up a narrowband sensor, power up the Microtech and then heat the sensor with a propane torch. It should read almost full lean.
Old Sep 16, 2007 | 06:11 PM
rx72c's Avatar
Top Answer: 1
why would you want to use the narrowband sensor anyway?
completely useless in my opinion.
send the microtech back to get it upgraded to wideband.
Old Sep 16, 2007 | 09:49 PM
dean23's Avatar
pwned
well i had a narrow band sensor connected beofre i installed the wideband, and that SEEMED to work, but now im not completely sure..
mulcryant
Oct 4, 2015 12:18 AM
