Is my shifter stock or not?
Old Sep 14, 2007 | 09:25 PM
510wagon's Avatar
I bought a 88 rx7 for the motor and trans for my 510 and i was told the shifter was a racing shifter or something? he didn't really know what it was but it had a lot of play in it so i took it out and there was bushings missing from it. well i got some from my friends old trans. its very tight and works good now. but i wanted to know if it is stock or a short shifter. how far is the throw from 1st too 2nd with a stock shifter?
Old Sep 14, 2007 | 10:48 PM
farberio's Avatar
NASA-MW ST4
Why not post a pic instead?
Old Sep 15, 2007 | 06:02 AM
510wagon's Avatar
ya ill get one later today i think it is stock but I'm just use to my other car.
would the throw be as much as a 1st gen rx7?
Old Sep 15, 2007 | 10:06 AM
K-Tune's Avatar
FD Daily
should be able to tell just by looking at the shifter lever itself. stock is a 2 piece system with rubber holding it together in the middle.
most aftermarket ones are just 1 solid piece of metal.
Old Sep 15, 2007 | 11:14 AM
510wagon's Avatar
ya i think its stock. it just seems like its a short shift because I'm use to driving a e30 bmw.
Old Sep 15, 2007 | 08:17 PM
misterstyx69's Avatar
Retired Moderator, RIP
the only way that you can "really tell" is to Pull the Shifter from the Trans.If the shifter ball at the bottom is about an inch and a half from the bigger Pivot Ball,and there is an Extra Collar where the pivot pin is,and sitting on top of the Transmission,Then you have an Aftermarket shifter.You could always take a look and compare them on Mazdtrix's Website Or Ebay..Also some of the Aftermarkets are Two piece.There is a One piece aftermarket shifter out there.I can't recall the place to get it though.(and I was going to get it too!..Damn!)
Old Sep 16, 2007 | 01:32 AM
K-Tune's Avatar
FD Daily
the C's is a 1 piece, i have one
Old Sep 16, 2007 | 06:23 AM
510wagon's Avatar
well it probably is stock. my friends 1st gen is a much longer throw, not sure how much shorter the 2nd gen is compared to it.
