Microtech Microtech Lt8 and Wideband AF
Old Sep 14, 2007 | 04:16 PM
BluRR's Avatar
I have an A microtech Lt8 with the harness adapter and a Innovate LC-1 wideband. Do i hook up the wideband ecu output from the LC-1 to the stock narrowband input on the car? Will the lt8 read the wideband and do so accurately? Is there anykind calibration required?
Old Sep 14, 2007 | 04:22 PM
BluRR's Avatar
Also when hooking up the map sensor do you still need the stock map sensor to be connected, becuae i dont have the stock map sensor.
Old Sep 16, 2007 | 09:56 AM
Aaron Cake's Avatar
Engine, Not Motor
The LT8 only accepts a narrowband O2 signal. You need to connect the simulated narrowband signal from the LC-1 to the LT8s.
Not sure about what you are referring to with the MAP sensor. The Microtech uses it's own MAP sensor which needs to be plumbed to a vacuum source on the manifold. The stock sensor is just there to drive the dash gauge at that point.
Old Sep 16, 2007 | 06:13 PM
rx72c's Avatar
Top Answer: 1
stock map sensor not required for microtech.
Old Sep 17, 2007 | 01:56 PM
BluRR's Avatar
Thanx guys. much appreciated
Old Sep 17, 2007 | 02:32 PM
jiggaFlexxx's Avatar
Need help? give me a call.
Old Sep 17, 2007 | 07:39 PM
88t2romad's Avatar
(_8(|)
Aaron, not sure what you mean by "simulated signal". Can you further explain?
My car has the LM-1 kit on it.
Old Sep 19, 2007 | 10:18 AM
Aaron Cake's Avatar
Engine, Not Motor
Some widebands have a simulated narrowband output. They translate the 0-5V of the wideband to the familiar 0-1V of the narrowband. This is so you only have to run one sensor.
Old Sep 19, 2007 | 11:55 PM
88t2romad's Avatar
(_8(|)
thanks aaron, ill look further to see if my bosch will work
mulcryant
Oct 4, 2015 12:18 AM
