Has anyone ever experienced "instant" oil-seal failure?
Old Sep 13, 2007 | 06:34 PM
eriksseven's Avatar
Make Money.
From my understanding, oil-control rings don't just "go bad"... It's a gradual wear-process, leading to excessive blow-by and increased oil-usage and smoking. Eventually it becomes unbearable and the engine must be rebuilt.
Well, I recently got a really good deal on a 1987 Turbo II that had been sitting for about two years, but only had 102k miles on it. I purchased it, and it drove home OK and ran with absolutely no smoking... My intention was to clean it up and replace a lot of the worn-out items in the engine-bay--basically freshen it up.
Well, I start it up after a full tune-up and engine-bay clean-up and the thing starts smoking... smoking like crazy. As the engine warms up, the smoke increases to the point of being ridiculous--so I just shut it off and came inside.
Obviously I'm hoping it's the turbo, because as far as I know, turbo oil-seals can just "go bad". I'm just crossing my fingers it's not the engine. Anyone ever experienced "instant" engine oil-seal failure--or should I be focusing the blame 100% on the turbo...
Thanks for any response.
Old Sep 13, 2007 | 10:08 PM
YaNi's Avatar
RIP Mark
Are you sure the smoke is burning oil? If its white it could possibly be coolant also...
Old Sep 13, 2007 | 10:13 PM
RETed's Avatar
How can you be sure?
Pull the spark plugs and look at them...
If the oil control rings are the culprits, the spark plugs will tell you...
(With the exception if the turbo compressor side pukes so much oil, but pulling the intercooler hoses will confirm this.)
So...
1) Pull IC hoses and check for oil.
If that's clean, then...
2) Pull spark plugs...
-Ted
Old Sep 13, 2007 | 11:50 PM
eriksseven's Avatar
Make Money.
So...
-Ted
Sounds like a plan. I guess my main question was: Can oil control-rings just "go out".... Like, good one day--smoking like crazy the next.
Old Sep 14, 2007 | 12:40 AM
RETed's Avatar
Yes, it's possible.
-Ted
Old Sep 14, 2007 | 03:00 AM
eriksseven's Avatar
Make Money.
Yes, it's possible.
-Ted
Son of a bitch... Well, that's possibly $500 I didn't want to spend on a rebuild, lol.
Let's just hope it's the turbo... I checked the plugs and they had some black residue on them after 20 minutes of run-time. I guess I'll know by tomorrow.
Old Sep 14, 2007 | 03:43 AM
TehMonkay's Avatar
Back in the game
Soft seal kit is only $300, not $500
Old Sep 14, 2007 | 07:14 PM
eriksseven's Avatar
Make Money.
If I rebuilt the engine I'd buy new all new springs, coolant seals and contol-rings with inserts--probably over $500, considering control-rings are $200.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
WyomingTII
Rtek Forum
Oct 26, 2015 05:26 PM
BUSTN
Sep 21, 2015 05:01 PM
