17x7 40mm offset.
Old Sep 12, 2007 | 01:53 AM
rx7-kid's Avatar
Incomplete Project
17x7 40mm offset.
I read the thread but i couldn't find the answer that i am craving for. I'm getting a 17x7 with 40mm offset. I'm trying to run 215/45/17 up front and 225/45/17 in back. i have tanabe springs with tokico strut. i havent fix the camber in the back but i will do it soon. would it work without rubbing on the springs. or would the negative camber in the back make the back tires rub. How much is the speedometer going to be off. I look it up in a site and they say that it'll only throw it off a little bit. Could it be possible to run 225/50/17 or 215/50/17 on the back with out rubbing, thanks
Old Sep 12, 2007 | 02:03 AM
TehMonkay's Avatar
Back in the game
There will be no problem fitting that.
Old Sep 12, 2007 | 03:36 AM
RETed's Avatar
They will not fit up front due to the POS Tanabe springs.
-Ted
Old Sep 12, 2007 | 09:08 AM
rx7-kid's Avatar
Incomplete Project
so the front would not fit 215/45/17. the rear would fit 225/50/17. correct. If 215/45/17would not fit front with the tanabe springs then it should fit 205/45/17or 205/40/17.
Old Sep 12, 2007 | 11:04 AM
RETed's Avatar
Rears not a problem.
You're not supposed to be adjusting tire size for clearances.
The proper size is supposed to be a 225 / 45 / 17.
You can run them up front, but you'd need a spacer to clear the (bigger) Tanabe springs.
-Ted
Old Sep 12, 2007 | 03:44 PM
TehMonkay's Avatar
Back in the game
You'd figure aftermarket springs would be made so they dont hinder tire clearance.
Old Sep 12, 2007 | 10:54 PM
RETed's Avatar
Yeah, too bad both the Tanabe (GF210's?) and the Tein's *DON'T*.
Do a search in this section to see pics...
-Ted
Old Sep 13, 2007 | 05:50 AM
TehMonkay's Avatar
Back in the game
Well i heard about the teins doing it, not about the tanabes though.
Old Sep 13, 2007 | 06:11 AM
RETed's Avatar
Check it out...
https://www.rx7club.com/suspension-wheels-tires-brakes-20/pic-front-tire-rubs-spring-coil-buttom-when-making-u-turn-going-thru-curvy-surface-576621/
-Ted
Old Sep 14, 2007 | 04:00 PM
rx7-kid's Avatar
Incomplete Project
thanks
