Front or Rear Rotor I can't tell!!!
Old Sep 10, 2007 | 03:03 AM
asiandude15's Avatar
Ok so I am getting back to my project and I have the two rotors for my engine here and I can't remember which one is the front or rear rotor... How can I tell which is which? They are stripped of all the seals already...
Old Sep 10, 2007 | 05:36 AM
RB_eater's Avatar
Leah Dizon > Roast Beef
I dont think there's a difference. Aren't the two rotors only supposed to be close enought in weight (2 letters?)?
Old Sep 10, 2007 | 08:50 AM
RX7Tuner.'s Avatar
I really Schruted it
There isn't a difference. The housings have a front and rear marking but even that doesn't matter.
Old Sep 10, 2007 | 09:41 AM
Aaron Cake's Avatar
Engine, Not Motor
However, there is a difference in wear if the rotors are used. It's best to put them back in the same spot. If you can get a good look at the apex seal groove, you may see that it looks like a slight "V". The straight side will be the leading edge, the slanted side will be the trailing edge.
tsmith94FD
Aug 16, 2015 05:41 PM
