shift/redline buzzer to shift/redline light
Old Sep 9, 2007 | 01:30 PM
fidelity101's Avatar
Rallye RX7
I am officially tired of the buzzer and while I am switching dashes I'd figure I'd take this time to make the shift buzzer a light instead, I already mounted a spot on the cluster for a light, I will probably use LED or just like a small 194 one or w/e
anyways I have been searching and cant find anything useful.
but I know other people have had this same idea as me!
right now I figure that im just going to interrupt the circuit going to the buzzer and wire those leads to a light and put it in the mounting spot where I have it.
but do the other buzzers (IE oil and coolant) use the same one? so will i have warning light for those now too? will the buzzer still go off and have a light? (granted if I wire them in parallel?)
anyone got any good opinions or links that can help me out?
Old Sep 9, 2007 | 01:36 PM
Icemark's Avatar
The low oil and low coolant warning use the same shift buzzer as the redline.
A single LED wired with appropriate resistor should be fine wired in the circuit, but I personally would leave the buzzer connected as well.
Old Sep 9, 2007 | 01:37 PM
TOOSHORT_88's Avatar
"On the grind"
i took out the buzzer for redline and put in a green led and is really bright in the **** pit wen you hit redline, i have no idea if i elim, all the warning buzzers though.... had it like that for 4 yrs and no probs
Old Sep 9, 2007 | 04:01 PM
TweakGames's Avatar
FD pro licensed driver
I already did what you want to do.
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/shift-buzzer-590822/
http://youtube.com/watch?v=QuiIJ4UZZk4
Its easy, installed a relay where the stock buzzer would be. If you need a walkthrough let me know.
Old Sep 9, 2007 | 04:33 PM
Rallye RX7
https://www.rx7club.com/showthread.php?t=590822
I did find your thread actually
I enjoyed the diagrams
JoesFC
Oct 5, 2015 08:10 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
