SAFC antitheft idea!
Old Apr 6, 2002 | 06:09 PM
Wankel7's Avatar
Haven't we ALL heard this
I was fidiling with my S-AFC and noticed when it is idling I could move the LO setting and run it down to -50%. Causes the car to stall and start. But it will die quickly.
Ok, so you have a S-AFC and you park your car in the bad part of town. Run your S-AFC down to -50% after you turn the car off. She won't start!
Just an idea a friend had.
James
Old Apr 6, 2002 | 06:59 PM
rico05's Avatar
WTB S5 N/A FC
Or wire a hidden fuel cut switch in. But that sounds good too!!
Old Apr 6, 2002 | 07:00 PM
OPEC's Avatar
That is a good idea.. or you could just rig up a hidden switch that cuts the fuel pump, just an easier method of removing the connector that is under the steering column. And they will never be able to start it cause you won't get any fuel. This switch is mainly used to help if you have flooding problems. A lot of the guys I know around here have that rigged up.
Old Apr 6, 2002 | 07:48 PM
pp13bnos's Avatar
Pineapple Racer
Or just unhook the s-afc from the wiring harness. CJ
Old Apr 7, 2002 | 07:39 AM
Amur_'s Avatar
Refined Valley Dude
Sounds interesting. But what is an S-AFC?
ttyl,
Amur_
Old Apr 7, 2002 | 11:29 AM
WestJaxVert's Avatar
Air Fuel Computer...made by A'pexi.
Old Apr 7, 2002 | 01:28 PM
dwillms's Avatar
or just pull your egi fuse and keep it in your pocket.
Old Apr 7, 2002 | 04:00 PM
UniqueTII's Avatar
Slow and old
That's also a way to start a flooded car.
Old Apr 7, 2002 | 11:01 PM
Amur_'s Avatar
Refined Valley Dude
Don't have the flooding problem. And thanx.
ttyl,
Amur_
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
dexter snoek
Sep 29, 2015 09:18 AM
GKW
Sep 28, 2015 04:34 PM
