more hp= blown engine?
Old Apr 6, 2002 | 05:31 PM
execelon1's Avatar
Question more hp= blown engine?
i know that some of you have already posted on this but i have a tech question and i hope that you can help. say if you had an ELECTRIC SUPERCHARGER that you could install in line and it gave you ,say from 3-5 psi boost or maybe just a little more. would this make the mixture too lean and burn up the engine or would the afm compensate for this and make the adjustments ? if not what would i have to do to compensate for this extra forced air. a friend and i have made a device that does this and i want to get all the info i can before i install it. going to put it on a 88 na 13b. let me know what you think. thanks. PEACE> ex...
Old Apr 7, 2002 | 06:58 AM
I wish I was driving!
There's a reason no one is touching this... overall, it is a bad idea.
I would like to see this working design of a pump from you and your friend.
3-5 psi of boost would be fine on your car.
S/c should draw through the AFM, and not blow through.
AFM would compensate for this increase in airflow with more fuel.
Sean Cathcart
Old Apr 7, 2002 | 07:39 AM
bingoboy's Avatar
Lava Surfer
hmm 3-5lbs is more than i thot they had.
do you got a website for those electronic superchargers?
Old Apr 7, 2002 | 07:43 AM
All premade ones claim 1/2psi to one psi. as far as I acn tell, he is claiming to have built an electronic supercharger with one of his buddies.
Sean
Old Apr 7, 2002 | 08:17 AM
prmazdarx7's Avatar
here is one web sitehttp://www.electricsupercharger.com/
Old Apr 7, 2002 | 08:20 AM
I think the hideous women at the bottom of their homepage speak enough about the product if the company isn't doing well enough to hire attractive models...
Sean
Old Apr 7, 2002 | 09:44 AM
prmazdarx7's Avatar
their testimonialshttp://www.electricsupercharger.com/...am_testim.htm?
Old Apr 7, 2002 | 09:51 AM
prmazdarx7's Avatar
sorry to hear that you relly on a beutyfull woman to tell you a product is good or not
side note : i do not have the product nor i am defending the product
the reason i posted was because i did some search to contribute to the threat
so dont take my coments to heart ya know what i mean
Old Apr 7, 2002 | 03:03 PM
prmazdarx7's Avatar
i am interested on the points of view of what other people have to say about this product
and when i say people i mean rotary enthusiasts
Old Apr 7, 2002 | 03:40 PM
Scott 89t2's Avatar
SOLD THE RX-7!
it'll work for a few mins before your battery goes dead.. this is ment for very short use like NOS.
it draws 50amps...
hyperdaddy7's Avatar
i would want an afc if i got that, i wouldn't trust that if it was in my car...something about it just seems kind of ghetto. it is a good idea though.
Old Apr 7, 2002 | 05:09 PM
NZConvertible's Avatar
I'm a boost creep...
Quoted from an article from Autospeed, explaining why electric superchargers are useless on cars:
"So, how much power does it take to drive an efficient supercharger like a screw type? The most efficient type of supercharger, flowing 265 cfm and developing a boost of 11.5 psi, takes 14.5kW to drive it. Figures aren't readily available for centrifugal blowers, but they'd be of a similar magnitude. So the best blower design (the same type that's used on the Mazda 800) takes about 14,500 watts to drive it on a modest-sized engine. This power is derived from the engine via a belt connecting the blower to the engine's crankshaft.
But let's say that instead of using a belt-drive from the engine, we power the supercharger by using a 12 volt electric motor powered from the car battery. For an electric motor power of 14,500 watts, we'd need a current flow of about 1000 amps (14,500 watts divided by 13.8 volts = 1050 amps). So, to supply the current to drive an electric supercharger having the same airflow output as the most energy-efficient type currently available, it would take 1000 amps. To generate this much electrical power would require at least 8 heavy-duty alternators bolted to the engine. Furthermore, to handle this current, the wires connecting the battery to the supercharger would have to be enormously thick - perhaps brass or copper bars 10mm square would be needed."
Old Apr 7, 2002 | 08:16 PM
ReZ311's Avatar
KM48 Burnout
what a bunch of horse ****.
The Shaolin
Sep 14, 2015 07:50 PM
cdn
14
Sep 10, 2015 06:23 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
