rear brake pistons stuck!!
Old Apr 6, 2002 | 01:50 PM
JoeZoom's Avatar
zoom...to VROOM!!
Could be a couple of things...one, is your e-brake on or stuck on that side? Could also be some gunk build-up on the inside or could be the snap ring on the inside has come loose or maybe even broken. I would check the e-brake first though.
Hope this helps.
Old Apr 6, 2002 | 02:01 PM
MaxRX7's Avatar
hambre y sueño
yeah, I don't know of anything else it could be.
Old Apr 6, 2002 | 02:49 PM
N1XRR's Avatar
Well, I ran into that EXACT same problem...and thought I had to rebuild my caliper...
Here's what you do, notice those cut-outs on the piston? Yeah, take a 22mm(I think) wrench and turn the piston clockwise(I think) using the grooves. Thats the auto-adjust on the FC's.
Old Apr 6, 2002 | 04:11 PM
N1XRR's Avatar
Okay, you should probably go buy yourself a brake rebuild kit..its only like $10
Old Apr 6, 2002 | 07:14 PM
DC350's Avatar
Rotor Head
turn it counter-clockwise it wouldn't go in for me either. but use all your strengtch with a set of needle nose pliers. and u should be good
Old Apr 7, 2002 | 01:55 AM
Icemark's Avatar
did you double check that you released the parking brake?
Marty RE
Aug 17, 2015 09:36 AM
Marty RE
Aug 13, 2015 11:19 AM
