Radiator Question
Old Apr 5, 2002 | 10:13 PM
swoop's Avatar
Radiator Question
What is the temp sensor in the bottom corner of the radiator used for???
The ECU uses the sensor at the back of the water neck, the stock electric fan uses the sensor at the top of the water neck, and the temp gauge uses the sensor under the oil pressure sensor.
Anybody know???
Old Apr 5, 2002 | 10:17 PM
I wish I was driving!
Accelerated Warm-up.
Sean
Old Apr 5, 2002 | 10:27 PM
NZConvertible's Avatar
I'm a boost creep...
Yep, emissions control. It's actually just a switch that should close above 59-66degF. It's pretty much redundant once the air pump and ACV are removed.
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
