Haltech Cant load map. Need help!!
Old Aug 29, 2007 | 11:40 AM
Rx7phil's Avatar
Theres a particular map I cant load... Im using a E6K and the map was made for a E6K. When I try to load it this happen:
http://www.putfile.com/pic.php?img=6447323
http://www.putfile.com/pic.php?img=6447322
I tried to load a other map and and everything worked out well.
Thnx a lot.
Old Aug 30, 2007 | 01:35 PM
Claudio_Haltech's Avatar
EFI Tuner
One option, the map is corrupted, another option, the map was made with newer firmware/software version than what you have?
Thats about all i can think off.
Old Sep 4, 2007 | 11:44 AM
BDC's Avatar
BDC
BDC Motorsports
+1.
B
Old Sep 4, 2007 | 11:17 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
A little piece of advise, when sending Haltech maps via email, ALWAYS zip them, sometimes they will get corrupted or attached wrong or assumed as viruses on the email programs and this will cause problems.
Another thing to watch out for is when you do get the map in its direct format (not zipped) when you "save as" make sure the file type field is set to "All Files" otherwise Windows sometimes assumes the file is a TXT file and will change the extension and this also causes problems.
And finally, another tip on map manipulation, map files DO NOT have file assosiation to the Haltech program, NEVER try double clicking the map file to load it, always open the program and load the file from there, also, ive seen people try to drag and drop the map file onto the program to open it, this doesnt work either, as well as people trying to open the map file from within the ZIP file if its in there.
The correct way to open a map file is by opening from withing the Haltech program which ever it may be.
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
nismorx7
Power FC Forum
Oct 1, 2015 10:36 AM
freq
Haltech Forum
Sep 13, 2015 07:45 AM
