Power FC pfc base map question...(midpipe)
Old Aug 28, 2007 | 05:34 PM
preludesh2000's Avatar
i installed my pfc and everything is good ...
i have re v-mount ic ... greddy intake.... dp ....stock twins (10-8-10)(ported wastegate)
just removed the air pump, installed pulleys...and have my rx7store midpipe sitting in the garage...
still running the cat...and stock catback(for now)
was wondering if the base map can handle the midpipe install...
or will i need to be tuned (asap) ???
also when i install a aftermarket catback (i'm assuming it will need tuned then)
just wondering how many mods draw the line...
thanks guys
brad
Old Aug 28, 2007 | 11:50 PM
cewrx7r1's Avatar
Eye In The Sky
If your PFC has the base mod map which they usually come with now:
(1) timing will be more safe than needed
(2) fuel should be OK with the cat, but I would not trust it for the MP.
Old Aug 29, 2007 | 08:26 AM
thats what i thought...
if i installed a catback and midpipe would the map be good enough for a 3hour drive ....
brad
Old Aug 29, 2007 | 09:17 AM
cewrx7r1's Avatar
Eye In The Sky
It depends on how you drive the car. Low or no boost = safe, high boost = not safe. You need to study up on engine dynamics and how maps are used.
Old Aug 31, 2007 | 12:00 PM
Jodeny's Avatar
Indifferent
If you have the 5.08 map it will handle the midpipe as long as you keep boost below 13 pounds- spike it past there and you are taking a big chance.
John
24seven_dada
20
Nov 10, 2018 12:03 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
Mps_hell
Sep 19, 2015 10:02 PM
