Coughs at idle
Old Aug 27, 2007 | 06:57 AM
Macen's Avatar
Coughs at idle
My newly mild streetported engine is running fine and smooth when driving, but at idle it coughs/stutters.
Running everything stock including ECU.
What can cause this? Bad timing? Running too rich? Is it bad for the engine to run like this?
Film clip, engine at idle
Old Sep 26, 2007 | 04:02 AM
Macen's Avatar
Bump.
Old Sep 26, 2007 | 08:11 AM
crazyrx7's Avatar
Big Daddy!!!
Your video link doesn't work.
What rpm is it idling at? Is the idle hunting (reving up and down)? We need more info please.
R.K.
Old Sep 26, 2007 | 09:06 AM
Macen's Avatar
Odd, the link works fine here. http://macen.nullnet.com/film/DSCN1308.avi
It's idling at 800rpm and is not hunting.
Old Sep 26, 2007 | 09:10 AM
Mahjik's Avatar
Mr. Links
The link worked fine here (SAVE AS).
Unless the *mild* streetport is not so mild then it does seem to be running a little strange at idle. I would start by checking the following:
1. O2 Sensor. If you didn't replace this with the engine, now would be a good time.
2. TPS adjustment. Make sure the TPS is adjusted properly
3. Spark plugs. If seen some new rebuilds foul plugs pretty quickly in the beginning. They can usually be cleaned with a spark plug cleaner if you have access to one otherwise just change them out after about 300-400 miles.
Old Sep 26, 2007 | 09:44 AM
Macen's Avatar
Sorry, I should have added this earlier in the thread:
TPS is checked via my Power FC (connected it just to check the voltages, now I run stock ECU). Voltages at idle and at WOT are within specs.
I have tried with new plugs (BUR9EQP L & T) but no change.
Haven't replaced the O2 though.
I have also removed the IM and checked all vacuum hoses, and they are connected correctly.
Plug wires (NGK) are brand new.
Thanks for your replies.
Old Sep 26, 2007 | 10:08 AM
Mahjik's Avatar
Mr. Links
Arrow
Here's a good thread for you to take a look at:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/driveability-improvement-secondary-throttle-plate-adj-o2-sensor-repl-687859/
Old Sep 26, 2007 | 10:26 AM
Macen's Avatar
Thanks. I will give that a try.
Old Sep 26, 2007 | 10:47 AM
Montego's Avatar
Don't worry be happy...
Top Answer: 1
Macen,
I had that exact issue as you. I also had a mild streetport with the stock ECU. I tried several grounding points, checking plugs, new O2 sensor. And nothing. My understanding is that with the stock ECU the O2 sensor readings are all jacked due to the porting. So the control system keeps on trying to correct it self and what you end up is with a cough at idle. Or a miss.
FYI- My fix came when I got a Power FC.
Old Sep 26, 2007 | 03:43 PM
Macen's Avatar
montego: Good to hear, I had that in my mind too that the stock ECU is the problem. I will have the engine maped with the Power FC then. But first I need a bigger IC and probably a V-mount. Already got a Koyo N-flow rad. :-)
SRTx781
Dec 19, 2015 07:30 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
Jmpabon93
Sep 30, 2015 04:57 PM
