Please recommend supplier for new Thermostat
Old Apr 5, 2002 | 07:45 AM
'Vert in Vegas's Avatar
Is the Mazda factory thermostat necessary, or are
aftermarket ones acceptable?
Who is a good source?
Thanks!
Old Apr 5, 2002 | 07:50 AM
RETed's Avatar
I use and recommend Mazda thermostats.
-Ted
Old Apr 5, 2002 | 08:14 AM
J-Rat's Avatar
Alcohol Fueled!
I have heard from more then a few people that the Mazda thermostat is the best one. I a running a cheap-*** Stant from Checkers, but I am changing that soon.
Rat
Old Apr 5, 2002 | 08:45 AM
SureShot's Avatar
Seduced by the DARK SIDE
Mazda brand always fits. If you get sometning else, check the reach dimension of the spring loaded disc under the stat. It controls the bypass flow (for high revs). I had an aftermarket stat that didn't seat on the bypass port. It gave symptoms like a partially blocked radiator.
Old Apr 5, 2002 | 10:07 AM
FEDREX's Avatar
"Just Looking".......
The Mazda oem is about $14. why use another?
Old Apr 5, 2002 | 10:21 AM
rxseven's Avatar
Special Dark
I've heard (but never used) that the 180 deg. ones from Victoria british are decent also.
Old Apr 5, 2002 | 11:59 AM
J-Rat's Avatar
Alcohol Fueled!
Mazda dealer was closed that day....
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
rotor_veux
Sep 28, 2015 09:25 PM
MidnightOwl
Sep 25, 2015 10:24 PM
erevos
Sep 15, 2015 09:19 AM
