fuel pump with stock ecu question....
Old Apr 4, 2002 | 11:43 PM
TainoIndian's Avatar
I am looking at getting ecu once i get tax return...yes finally!
with my mods so far no probs most its spiking is 12psi, cold nights i stay off the gas because it jumps high!!
i but for now i am lookin at getting a better flowing fuel pump for now with my stock ecu would it cause any probs and run fine or will it cause errors? i thinkin might as well get it now and bolt on cause i will need to in the future.....i know it will not make boosting safe due to stock ecu because i need that to control air fuel to not run lean but just wanting to know if any ill effects on putting it on now......
Old Apr 4, 2002 | 11:59 PM
Lost Time's Avatar
Chimera Driver
Your thinking is correct. You will have no problems with running a new pump now, it's just good to plan ahead.
Old Apr 5, 2002 | 12:07 AM
good!
just worried it would for some reason run rich or sumthin?
what fuel pump would you recomend i have heard supra pump...but i really dont want a supra part in my car.......what else is a better or equevelent?
Old Apr 5, 2002 | 12:49 AM
Zoomspeed's Avatar
I've been told teh walbro pumps flow really well and there only $130
Old Apr 5, 2002 | 01:43 AM
alwan16's Avatar
i don't believe you need a new fuel pump unless you upgrade injectors. read this page carefully and it could save you some money for the time being.
http://www.newwave.net/~flanham/wlan...l/fuelfaq.html
Old Apr 5, 2002 | 03:03 AM
rynberg's Avatar
I've heard some of the tuners have had problems with Walbro pumps failing early. The Nippon Denso pump (Cosmo style pump, I believe) will work great for you, as it is a drop-in replacement. You can get it from the rx7 store or rx7.com for pretty cheap.
