Pettit AST question
Old Apr 4, 2002 | 09:54 PM
Pumped's Avatar
Pettit AST question
ok heres a retarded Q, what is the proper way to remove the saftey cap off the ast,
is it lift up saftey lever, then twist and remove
of lift up saftey lever wait till pressures released then put it back down then twist and remove....
because i bought a 16psi replacement, and the lever for the cap does not stay up like the on pettit supplied, I'd lift the lever and it will snap back down when i let go
so just wondering..
Old Apr 4, 2002 | 10:36 PM
Lost Time's Avatar
Chimera Driver
I would take the cap off the filler neck to release any pressure that might be in the system before removing the ast cap. And protect your eyes.
Old Apr 4, 2002 | 11:18 PM
Import Convert's Avatar
Put a rag over either cap if you are removing it while hot!
Old Apr 4, 2002 | 11:27 PM
Zoomspeed's Avatar
isn't that what the lever is for though?
Old Apr 4, 2002 | 11:48 PM
spooledUP7's Avatar
There and back again
lift the lever first.
Old Apr 5, 2002 | 03:23 PM
Pumped's Avatar
man you guys aren't reading my post properly
Old Apr 5, 2002 | 03:24 PM
Pumped's Avatar
so is it lift lever, keeping lever up and remove
or
lift lever, snap lever back down then remove?
Old Apr 5, 2002 | 04:08 PM
Toadman's Avatar
Nomad Mod
lift lever releasing pressure(use a rag and read the warning on the cap), push down and twist left. Leave lever up when unscrewing.
_Tones_
May 25, 2021 05:37 AM
24seven_dada
20
Nov 10, 2018 12:03 PM
msilvia
15
Sep 11, 2015 12:13 PM
Nosferatu
Sep 5, 2015 02:13 PM
