How much damage will a blown water seal do?
Old Apr 4, 2002 | 01:20 PM
dra_gon_lee's Avatar
Question How much damage will a blown water seal do?
I was interested in a 87 N/A for a project/mess around car. The owner says it has a blown water seal, but he is including a entire new gasket, and seal set. Its 600 dollars, just wondering, if the water seal is blown what would it take to fix? Would the rotors or housings be messed up? What should i look for if i go and check it out? Also it says theres a new tranny and clutch, and the body is good only one scratch...
thanks
rocky
Old Apr 4, 2002 | 01:29 PM
RETed's Avatar
If the seal just went, then you're looking at a straight rebuild.&nbsp the problem with blowm water seals is that it is usually caused by a failing water jacket IN the side housing.&nbsp This added several hunderd dollars for a new housing...
-Ted
Old Apr 4, 2002 | 01:37 PM
tmak26b's Avatar
you need to rebuild the motor, cahnces are that his rotor might be warped because he overheated it
Old Apr 4, 2002 | 06:40 PM
i was thinking the housings would be bad too, and the rotors are prolly bad also... now the guy wants 800 for it, i dont think im so interested anymore...
FD7KiD
15
Feb 26, 2021 10:12 PM
