Power FC Air Temp/power Fc
Old Aug 12, 2007 | 02:56 PM
jef57's Avatar
Question Air Temp/power Fc
Hi
Is Air Temp Value Accurate On Commander With Apexi Power Fc?
Air Sensor Location?
Thanks
Old Aug 12, 2007 | 04:45 PM
cewrx7r1's Avatar
Eye In The Sky
Yes, but it heat soaks under the UIM.
Old Aug 12, 2007 | 05:02 PM
jef57's Avatar
So Air Temp Value Get Low With Intercooler?
Old Aug 12, 2007 | 09:10 PM
puma's Avatar
canadian monster
I'll answer to him in french guys, i am afraid that was a weird question
Salut Jef, j'ai peur que les gars risquent d'avoir de la difficulté avec ton anglais
Si tu veux dire que ta température d'entrée d'air devrait être plus basse si tu ajoute un intercooler, oui. La température que tu lis sur le commander viens de ton capteur qui est sous le manifold du dessus.
Je ne sais pas si j'ai répondu à ta question, tu peux toujours m'envoyer un PM si tu as besoin d'aide.
Old Aug 12, 2007 | 10:03 PM
fendamonky's Avatar
F'n Newbie...
Can you translate that for the rest of us who don't speak French, but are still curious as to the answer?? hehe
Old Aug 13, 2007 | 08:30 AM
onemeansaturn's Avatar
Attorney to the stars...
Rough translation:
Hello Jeff, I am afraid the guys are likely to have difficulty with your English.
If you want to say that your inlet air temperature should be lower if you add an intercooler, yes. The temperature that you read comes from your sensor which is under the upper manifold.
I do not know if I answered your question, you can always send a PM to me if you need assistance.
Joe
Old Aug 13, 2007 | 09:21 AM
SPICcnmGT's Avatar
I'll try a shot at it.
The temperature is accurate as long as you are moving and getting air flow. But setting in traffic, it heat soaks and will read higher than it actually is. So it may say 50C but actually be lower than that.
The sensor is located under the upper intake manifold.
And with an IC should read lower, but will still heat soak if you are setting still due to the location of the sensor.
puma's Avatar
canadian monster
basically, he sent me a pm and wanted to know if the air temp sensor was measuring the air in the engine (after intercooler) or in the engine bay. Told him it was air going into the engine, after the intercooler, there was no point at knowing the engine bay temp.
Hey Joe, you understand french or you used a translator? If it's a translator, it is pretty accurate.
Old Aug 13, 2007 | 09:28 AM
Puma- I understand French to a certain extent. I used to be much better than I am now, but years of not speaking have made me a little rusty. I find I can still read French pretty well though. I got to shake some of the rust off when I took a trip to Switzerland/Southern France for a week in March and stayed with a friend's family. The children only spoke French and Spanish. They were just learning English. Forced me to get back into it.
Joe
FlatVermin
22
Sep 27, 2015 05:42 AM
