Undertray with a 20B FD
Old Aug 12, 2007 | 02:02 AM
gonzz's Avatar
Are people using a undertray with the Pettit subframe? I don't have one and it's over 100 degrees everyday here in Vegas. I need to get one. Any suggestions? Thanks.
Old Aug 12, 2007 | 08:50 AM
str8ryd's Avatar
Nearing Completion...
I don't have the Pettit Subframe, but I am using an undertray with my 20B setup. You should DEFINITELY get an undertray if you don't already have one.
I'm not too familiar with the Pettit set-up, but if you can't get any of the pre-made unndertrays to work, contact a metal shop and they should easily be able to make you one.
Old Aug 12, 2007 | 10:54 AM
gonzz's Avatar
Are you also running a fmic? I have the greddy. What thickness metal should i use? Thanks again.
Old Aug 12, 2007 | 11:35 AM
str8ryd's Avatar
I'm also running a Greddy FMIC.
Re Metal: I don't have a good enough answer to give you regarding that. Plastic undertrays are usually quite thin so I would suggest getting something replicated in metal with a similar thickness. Probably 1/2" or less thickness, but that's just an estimate and rough guess.
One of my buddies made his own in metal as well. If you'd like I could contact him and find out how thick his was? Let me know....
Old Aug 12, 2007 | 08:06 PM
gonzz's Avatar
Yea.. find out the thickness. I'll make one next weekend..
Old Aug 12, 2007 | 08:20 PM
allrotor93's Avatar
make 2 and i will buy one
Old Aug 12, 2007 | 08:22 PM
gonzz's Avatar
I'll let you know after i make mine..
Old Aug 13, 2007 | 08:59 PM
gracer7-rx7's Avatar
needs more track time
Hey Mr. G,
You can use any material including some acrylic/plastic type stuff. McMaster Carr has some good stuff cheap. Look under Raw Materials > Plastics > Sheets, Bars... > then look at Acrylic and Garolite.
I'm contemplating going that route when a friend and I are done with our v-mount kits.
Alternatively, Shine Auto Project has one for the FD that they sell for about $150.
From the other Mr. G.
Old Aug 13, 2007 | 09:07 PM
charlies7's Avatar
3rd rotors a charm
wow 1/2 in seems WAY too thick...I was thinking something along the lines of 1/16?
Old Aug 13, 2007 | 09:26 PM
gonzz's Avatar
Thanks Mr. G. lol.. I'll check out the McMaster site. I hear they have some nice stuff..
Originally Posted by gracer7-rx7
Hey Mr. G,
Old Aug 13, 2007 | 09:27 PM
gonzz's Avatar
I was thinking that or 1/8" .. Don't want to weight down the 20B..lol
Old Aug 13, 2007 | 10:00 PM
charlies7's Avatar
3rd rotors a charm
LOL...for sure...God knows that dont make power
Old Aug 14, 2007 | 10:35 AM
str8ryd's Avatar
That's why I said it was a very rough guess/estimate. You're the metal guy, not me .
Old Aug 17, 2007 | 09:01 AM
David Hayes's Avatar
^Pettit claims the 20B conversion works better without the undertray but I don't buy it. Would have saved me from my recent Nutria rat incident also I'm going to make one for my car when I get it back. Was going to go the sheetmetal route, something thin. Am going to take some cardboard and fab it up.
Old Aug 17, 2007 | 05:51 PM
t-von's Avatar
Rotor Head Extreme
^ I can't believe Cam would even say that. The main purpose for the under tray is to help flow the incomming air through the radiator.
Old Aug 17, 2007 | 06:03 PM
fwiw, plastic, acrylic, garolite is a bit more flexible than metal so it will fare better if you happen to hit or tap something like a parking lot curb or a driveway ramp.
Old Aug 17, 2007 | 07:54 PM
Yes, they removed mine with the conversion. I'm going to put it back though. Just makes sense for airflow.
Duc852
Sep 22, 2015 03:49 AM
