Microtech LT10S ignition problems T2 coil???
Old Aug 10, 2007 | 01:53 AM
Bad2ndgen's Avatar
Hello MT guy's, I just put an lt10s on a customers S4 and I'm having two problems that I can't seem to work out. First off the t2 coil is not firing, the coil is good at .5 ohms across the terminals, the plug wire is good at 1.2 ohms and the plug is not fouled. This pretty much leaves the trigger from the ecu or the igniter, I don not have an oscilloscope to check them but the T1 coil is firing fine so I think the igniter is ok. The T1 coil is wired pink to grey/red and T2 is wired white to grey/black as per the mt-8 wiring diagram, I assumed the lt10s is the same? Are there any settings in the ecu that can cause this? I know that MT is not good about letting people in on the trigger setting and such but it should be pretty strait forward and I figured some of you guys might know.
My other problem is the thermo fan control, controlled by the aux output is not working properly. The auxFAN function will not turn it on, I have the auxRPM and auxMAP set to off but the output will not turn on when the engine reaches the turn on temp. I am able to turn it on with the auxRPM function though? I'm sure this is just something I'm overlooking with my limited MT experience... Any ideas?
Thanks in advance.
Justin
Old Aug 11, 2007 | 01:52 AM
Bad2ndgen's Avatar
Please disregard, got it all figured out... Maybe if I would have received a lt10 manual instead of an lt8 manual with the lt10 ecu! It would have been much easier. Funny though, I acually got the car to run quite well with an ecu that was not designed to run the stock coils! Ha ha.
Old Aug 11, 2007 | 06:45 AM
hondahater's Avatar
spending too much money..
I think I may have the same problem (got an lt10s and an lt8 manual). Whats the differance between the lt8 and lt10s? I thought it was just the x4 ignition box?
Old Aug 11, 2007 | 02:08 PM
Bad2ndgen's Avatar
I was told nothing of the x4 ignition bow when I got the ecu and was given the lt8 manual... That was fun sorting out. The only other thing I found is the thurmo fan control is not on Aux1 but on Aux2 white/red wire.
Old Aug 11, 2007 | 05:10 PM
hondahater's Avatar
thanks for that info. Do you mind letting me know exactly how you setup the trailing coils on the x4 ignition box? I saw the instructions and got a bit confused. Thanks.
Old Aug 11, 2007 | 10:14 PM
boriqua51371's Avatar
where did u guys pick up your micros ?
Old Aug 12, 2007 | 07:20 AM
hondahater's Avatar
the guy that bought the one I had bought it from andy at world wide racing. www.wwrturboinjection.com however I have a friend right now selling an lt8 with brand new harness and laptop adapter for cheap. His name is Sonicrat on the forum. pm him and ask him about it.
Old Aug 12, 2007 | 03:49 PM
thanks.
Old Aug 12, 2007 | 03:58 PM
i didnt realize the company name i tried dealing with this peeps before and the customer service stinks bad. but thanks again.
Old Aug 12, 2007 | 06:07 PM
hondahater's Avatar
you sure it's the same place? The've been really nice to me answering any questions I've had.
Old Aug 12, 2007 | 07:53 PM
yep . check out there ebay score as well . but it doesnt matter thanks nevertheless , i send a pm to your boy just waiting on reply . do u know if his lt8 is new or use and why he selling also pricing ?
ZacMan
Sep 19, 2015 09:20 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
