clogged injectors
Old Apr 3, 2002 | 09:14 PM
Question clogged injectors
ok, ran the car out of gas , never started (and idled) afterwords..... so, what happened here? with a fuel cut switch i can make it run till 650(really ruff though), so, i am letting it sit, can i clean and test my injectors my self?????? does any one know where i can get really cheap injectors???????
Old Apr 3, 2002 | 09:15 PM
dre_2ooo's Avatar
Sorry man, when I replaced my engine, I was curious about injectors. The dude said they were $200 PER injector (dealership)
[Series 5 engine]
Old Apr 3, 2002 | 09:17 PM
RETed's Avatar
Try and find a contact number for Victoria British - they sell them for like $75/each.
-Ted
Old Apr 3, 2002 | 09:18 PM
Sniper_X's Avatar
Did you prime the injectors?
There is a connector to do this on the psgr fender well.
88-91 is a yellow two connector thingy that you have to short the two together.
I think that older versions just have 1 connector that you ground.
either way, if you turn the key in the run mode, then connect the prime connector to the right place, you should hear gas flowing.
after the whooshing and whining sounds are gone, you should be able to start (or flood start) the car.
Old Apr 3, 2002 | 09:46 PM
they don't really stop priming, after the whirring sound, i can still hear fuel moving, like maybe through a inject stuck open??????, and i just pulled out my dipstick.............., i thinking my oil is more gas than oil ....... ........, damit
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
loganneet
Oct 3, 2015 07:51 PM
