48 IDA tuning help...
Old Jul 31, 2007 | 06:34 PM
repumax's Avatar
Putting it on a stock early style 13b with header. Here is what I have.
48 Ida
42mm chokes (venturies)
F-11 Emulsion tubes
240 Mains
170 Air corrector jets
F10/70 Idle jets
Just want a starting point.
Thanks,Max
Old Jul 31, 2007 | 07:16 PM
ricksrx3's Avatar
try 55 idle jets and 190 fuel and 150 air that should get you started
Old Jul 31, 2007 | 08:20 PM
R.P.M.'s Avatar
Likes to swear....alot
48 Ida
F-11 Emulsion tubes
240 Mains
F10/70 Idle jets
Thanks,Max
That looks like it was setup for a 12A bridgeport
Old Jul 31, 2007 | 08:30 PM
Jaime Enriquez's Avatar
OLDROTA
Chokes are a bit big, as is the rest of it, for a stocker that is.
I would try: 40mm chokes
65 or 70F9 idle
F-11's
The 190main/160air combo is a decent place to start.
Old Jul 31, 2007 | 08:44 PM
Siraniko's Avatar
RX for fun
42's are fine. I have tuned Dave's white SA with 42 venturies and somewhat similar jets and it ran hard.
idle jets, maybe go a little bigger to 70-75 to elminate bogging during transition around 3000 RPM plus closed valve @ bottom of fuel bowl and rotaries like 3 progression holes. ALl other mods on IDA, search under my username and you wil find lots of info.
Old Aug 1, 2007 | 06:51 PM
repumax's Avatar
Thanks for the help. I'm taking it apart to clean and beadblast. Got a new master rebuild kit and the manifold is on its way. Do I need to get a fuel pressure regulator with a return line?
Old Aug 1, 2007 | 07:26 PM
Siraniko's Avatar
RX for fun
Im running a holley red with holley regulator set at 6psi. no return. But if you're going with a holley blue, use a moroso fuel log instead of holley/mallory FPR. Thats my next route as it is highly recommended by a knowledgeable/experienced builder.
Old Aug 2, 2007 | 12:16 PM
repumax's Avatar
Got it all apart and beadblasted last night. Just ordered some parts from Jaycee Enterprises. Should have it back together next week. Hey wacky what is a fuel log and whats the difference between a holley red and blue?
Old Aug 2, 2007 | 12:30 PM
Siraniko's Avatar
RX for fun
Red = 7 max
Blue = 14+
Fuel log works just like a Holley fuel pressure. A fuel log closes the line once the fuel bowl is filled and returns excess gas back to the tank whereas a holley FPR limits the pressure to the carb. Similar to Mallory 4309 FPR for turbo application but without a vaccuum line. Jack has been using this in his VW motors.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
demetlaw
Oct 2, 2015 06:22 PM
