1st gen Brake Upgrade
Old Apr 3, 2002 | 02:50 AM
abeomid's Avatar
So what happend to that brake upgrade to 2nd gen 4piston that ppl were talking about and somebody was working on making one?? I would really love to know that's going on with it.
Old Apr 3, 2002 | 02:51 AM
79+80_rx-7's Avatar
ME TOO
Old Apr 3, 2002 | 09:30 AM
yayarx7's Avatar
Are you Nucking Futs?
I got a pm from Guru a little while back, and he said that it was still in the works and he would keep me informed.
Old Apr 3, 2002 | 10:14 AM
Max7's Avatar
Admitted Sevenaholic
I gave up, and have gone a different route. Plus the fact of having to buy new 5 lug front rims is out of the question since I just bought new rims
Old Apr 3, 2002 | 10:44 AM
JDuncan's Avatar
From the Facts section at Mazspeed.com:
Old Apr 3, 2002 | 11:11 AM
abeomid's Avatar
What is this guy's email address so I can contact me. He makes it look really easy in there which is not. The most important thing for me is to have the fron hub setup from a TurboII with the bolt pattern of GSL-SE, so I can put upgrade 12" and 13" rotors in the front. If someone know how I would contact this guy to ask some questions, it would be appreaciated
Old Apr 3, 2002 | 11:36 AM
Max7's Avatar
Thats about all the info you get, he wrote the article to answer the questions people had about his upgrade.
It's a bad design, due to the fact when you need to replace your brake rotors, you will need to make another custom set of rotors, instead of ready made bolt on ones.
Old Apr 3, 2002 | 11:52 AM
riffraff's Avatar
smog nazi destroyer
so is anyone going to make a bolt on kit then?
Old Apr 3, 2002 | 12:01 PM
Max7's Avatar
I have thought about it, but it could come back and bite me in the ***, would have to sell them as "Off Road use only" "No Warrenty" "Legal paper stating as such so someone can't come back and sue me"
The the biggest stumble when making anything and selling it for first gen's
I'll see how easy it is to duplicate my setup when I find a spare set of GSL-SE struts and the costs associated.
Then there is the "What works on a GSL-SE may not work on a GSL due to brake balance front to rear"
So if I ever did sell them, they would be sold only for the GSL-SE since designing another complete kit for the GSL would be to timing consuming.
Oh to be unemployed and have tons of spare time.....
Old Apr 3, 2002 | 12:27 PM
abeomid's Avatar
Ok I have a GSL-SE and I would pay you right now, if you make me the brake upgrade, specially for the front, I don't care as much in rear since my road using it should be biased anyways. I even right you something that I won't hold you liable if something went wrong.
I would appreciate it if you consider this.
PM me or email me omid@bcrx7.com
thanks,
Omid
Old Apr 3, 2002 | 12:30 PM
peejay's Avatar
Old [Sch|F]ool
Hey Max7, I'm unemployed and have tons of spare time (interviewing for a dealership job though - wish me luck!)
Tom Turner's idea (as outlined on your site) looks rather easy and promising. After I replace my strut housings, I'll use one of the old ones to make a jig. GSL-SE housings are the same as '84-up 12A housings. I could do all of the machining operations to the GSL-SE rotors with a simple brake lathe and patience. I also have a few industrial lathes/drill presses/other goodies in my basement still in the manufacturer crates, just waiting for the basement to get cleared out so we can set up a small machine shop.
Also, even after I get a job, I'm roughly $10k in debt and at least one creditor is trying to garnish my wages (yeah, good luck - I have no wages right now ) so I'm going to need a second form of income if I'm going to make ends meet as well as support my RX-7 habit. My stepfather has his own small business, and I think I can ask him to help out with starting up.
Old Apr 3, 2002 | 12:54 PM
mar3's Avatar
Administrator
Peejay
Make a big brake set-up for each of the year breaks and they will buy. A simple bolt-on big disc and caliper adaptor bracket set-up for an '80 rex like what is available for my '68 Firebird (for $695 US, fronts only, $795 US for the rears...) is exactly what I'm looking for and now you even have a target price for your kit...get to work you unemployed bum! I did it for a year before I finally got in with SBC, so don't get depressed, things will work out. Good luck on the dealership job, just make sure it's part-time so we get our kits!!
Old Apr 3, 2002 | 01:15 PM
peejay's Avatar
Old [Sch|F]ool
I'd only want to sell the brackets and rotor hats necessary for the swap... the swap would use commonly available rotors ($29-up) rotors and ($100-up) calipers sourced from circle track suppliers. The neat thing about them is that everything is modular... so if you want, you can have a .810" thick rotor, or a 1.25" thick rotor, or a .375" thick solid titanium octagonal rotor, get rotors that have been cryo-treated, cross drilled, slotted, grooved, if they make it, they make it for circle track racers and it will fit behind a standard 15" steel racing wheel.
The only problem is the track calipers do not have dust boots and require rebuilding every year. Fortunately one can also use Delco-Moraine calipers (off of a GM) for greater durability at the expense of weight, but you'd still have the advantage of larger brakes and a VAST selection of pad compounds.
Old Apr 3, 2002 | 01:36 PM
riffraff's Avatar
smog nazi destroyer
do it up... i definatly would like to upgrade the brakes on my 79.
Old Apr 3, 2002 | 01:40 PM
zyounker's Avatar
root
I would be interested in the brace.. or even a whole kit for my GSL-SE monster..
-Zach
Old Apr 3, 2002 | 07:37 PM
fatboy7's Avatar
Got Boost?
Ooooo..... I want one, I want one!!!!
make one for 84-85 GS as well
Old Apr 3, 2002 | 07:45 PM
peejay's Avatar
Old [Sch|F]ool
I don't know how much of a good idea it'd be to make one for 12A cars. There are two different rotors for 12A cars vs. one rotor for GSL-SE. It would make more sense to make something for -SE because bigger brakes require bigger wheels, and bigger wheels are hard to find with 4x110 pattern.
The problem is, most people racing 4x110 are using 13" wheels, so there's no point in making a big brake kit because 12" rotors will not fit inside a 13" wheel. And the calipers in question are not streetable unless you don't mind rebuilding them frequently. That's the problem.
Old Apr 3, 2002 | 09:07 PM
mar3's Avatar
Administrator
You're not going into mass production. Make a bracket and hat combo that uses Wilwood calipers and sell them as a fitted set. The Wilwoods will have the seals to make them suitable for "set-and-forget" extended street use. Get a tax license so you can get components cheap and I think you'll make more money than you realize in this endeavor. I officially place myself first on the prototype testing for an '80 front set-up right now!
Old Apr 3, 2002 | 09:23 PM
Dyre's Avatar
Your Opinion is Wrong
What would be very cool would be a kit utilizing the TII hubs, stud pattern, TII capilers and rotors. That way you have a very easy reaplcment supply.
PLus you get 5 lug standard bolt pattern. Of course, you would need to build a kit for the rears too.
PLus the TII break stuff is quiet light being alluminum,
Old Apr 3, 2002 | 09:30 PM
mar3's Avatar
Administrator
Actually, that wouldn't be cool because you now have to throw away your present big wheel set-up and drop close to a $G for a new set. I want to use the 15" Weds I have now. I like the look a lot...
Old Apr 3, 2002 | 09:49 PM
riffraff's Avatar
smog nazi destroyer
i need new wheels anywas, so would love to go to a TII setup like dyre is talking about
Old Apr 3, 2002 | 09:59 PM
peejay's Avatar
Old [Sch|F]ool
Half of the FC brake conversion (detailed way, way above) is converting the hub and rotor to 4x110. If you wanted you could just leave it at 5x4.5".
As for the rears, just stuff a Ford 9" rear back there
Old Apr 3, 2002 | 10:32 PM
Max7's Avatar
The hubs above are 4 bolt from the base model, with 5 lug rotors modified to fit
I'm making my kit for myself, and should it prove easy/cheap to make, then I might sell them, but only for the GSL-SE, as I don't have time to design another kit for the 84-85 12A and 79-83 12A
I'm going the modified GSL-SE rotor hub way, so I won't need to worry about needing rims of a different offset or bolt pattern.
Replacement parts are cheap should the need arise, and swapping pads at the track is a breeze with the Wilwoods.
Now to find more spare time, to many projects, to little time.
Old Apr 4, 2002 | 02:02 PM
abeomid's Avatar
so anybody will do this anytime soon or this is all talk???? I need this upgrade and if you guys not doing it, please give me an email of a person that has already done it, so I can get some tips and make it easier on myself.
THanks
Old Apr 4, 2002 | 07:03 PM
Max7's Avatar
I'm doing it, no if's and's or but's.
I've already got the Wilwood rotors and Wilwood 4 piston calipers, and a new set of SE rotors to mill down, just waiting to find a spare set of SE struts with the stock brake mounting bracket so I can start to make measurments and begin the project.
