tire and fender flare help!?!
Old Jul 30, 2007 | 09:42 AM
Twinnos's Avatar
935 Wicked Dragger East
my 93 FD is at the body shop now and its gonna cost $500 to mold on some rear fender flares. now, i dont know if i really need them or not. my question is. i will be running 275/35/19 tires in the rear and need to know if i can run this size tire without doing anything to the rear fenders so they dont scrub or should i put the flares on? the rims will be 19x9.5 or 19x10 quick help will be appreciated. thanks
Old Jul 30, 2007 | 10:03 AM
Mahjik's Avatar
Mr. Links
What are the offset of the rims?
Old Jul 30, 2007 | 10:33 AM
Twinnos's Avatar
hey mahjik they are Offset: Front +24 mm & Rear +40 (this is what his ebay ad says, but i think he got it backwards. i think its rear +24mm and front +40mm either way let me know if this will work. thanks
heres the link: http://cgi.ebay.com/ebaymotors/19-In...spagenameZWDVW
Old Jul 30, 2007 | 10:38 AM
Mahjik's Avatar
Mr. Links
You are going to need the flares for a +24 10" wide rim (unless you want to look gangsta!).
Old Jul 30, 2007 | 10:43 AM
Twinnos's Avatar
do the fenders need to be rolled or can i they just mold them on and im good against scrubbing?
Old Jul 30, 2007 | 10:55 AM
Mahjik's Avatar
Mr. Links
What kind of rear flares are they? Ones like the Pettit require cutting which removes the problem you are thinking about.
Old Jul 30, 2007 | 11:57 AM
Twinnos's Avatar
they are the ones from shine auto for the burnout kit but i dont have the kit, just the flares.
Old Jul 30, 2007 | 01:37 PM
Mahjik's Avatar
Mr. Links
IIRC, those aren't all that big. You can probably just roll the fender and then add on the flare.
Old Jul 30, 2007 | 04:37 PM
allrotor93's Avatar
a 9.5 with a +24 may stick out a little up front
Old Jul 30, 2007 | 07:23 PM
Twinnos's Avatar
they are 19x8.5 rims +24mm up front with 255/35/19 tires and 19x10 rims +40mm rear with 275/35/19 tires with shine auto burnout fender flares. how am i?
Old Jul 31, 2007 | 10:36 AM
Mahjik's Avatar
Mr. Links
That's an interesting setup. To be honest, I don't think I've seen anyone run a similar setup on the FD. I would personally prefer to have a larger offset up front than the rear; rather than the other way around. I would highly suggest you look for some different rim.
You could always get them and see if they work and give you the look you want. If they don't work for you, you could put them back up on eBay.
Old Jul 31, 2007 | 10:47 AM
purerx7's Avatar
Registered User
+1, i have 19x9 on a 255/30/19 on a +46 offset and barely clear and thats with wide front fenders. Im having problems with it hitting the wheel well actually, anyways i dont think that your combination will work, sorry.
rx7jocke
72
Jun 17, 2016 03:48 AM
