Megasquirt leading coil overheats
Old Jul 28, 2007 | 02:11 PM
newmanmullen's Avatar
I am running a v3 msII with msextra firmware on an 88 13b.
Car runs great for about 10 minutes the falls flat.
I had to replace the leading coil due to a smoked power resistor in the bottom of the coil. (next to the ignter).
I had noticed the LED driving the leading coil pulses double time if not quad time on crank. (So fast at crank it looks as if the led is on solid.)
I believe this is the reason for the over heating coil. (On and above idle this may as well be a dead short.)
The question is how do I cut this pulse in half in megatune?
What setting may be causing this behaviour?
Thanks
Newmanmullen
Old Jul 29, 2007 | 12:02 AM
toplessFC3Sman's Avatar
I know that if it were MS1, i'd check the dwell settings to make sure you arent over-charging the coil, and "stim-for-wheel" being on can cause the RPM signal to read much higher than it actually is, thus making it fire more sparks. I dont know the MS2 too well though, and am not sure if these settings would be appropriate for it
Old Jul 29, 2007 | 09:40 AM
muythaibxr's Avatar
MegaSquirt Mod
Post your msq please.
Ken
Mps_hell
Sep 19, 2015 10:02 PM
The1Sun
Sep 7, 2015 10:21 PM
