Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D [need help] Wolf v4 PC to ECU cable
Old Jul 25, 2007 | 12:12 AM
hwnd's Avatar
watashi no shichi
hey guys - i need a cable for the v4 ecu to the PC or the pin-layout;
last resort is to pay AEM/Wolf $60usd for their homemade cable. I'm happy to buy a used cable here or build one if someone would be so kind to provide the pin-to-pin diagram.
Old Jul 27, 2007 | 12:30 AM
hwnd's Avatar
watashi no shichi
anybody?
Old Jul 27, 2007 | 01:11 AM
nyt's Avatar
nyt
Originally Posted by hwnd
anybody?
https://www.rx7club.com/search.php
Old Jul 27, 2007 | 08:10 AM
hwnd's Avatar
watashi no shichi
Originally Posted by nyt
the cable / directions posted do not work for my box or i followed the directions wrong (doubtful).
https://www.rx7club.com/wolf-3d-125/wolf-v-3-1-data-cable-429560/
...wow, a search option, what will they think of next?
Old Jul 27, 2007 | 12:59 PM
nyt's Avatar
nyt
https://www.rx7club.com/showthread.php?t=429560
did you make sure to connect the grounds on both sides? very important or you get signal noise.
Old Jul 27, 2007 | 04:22 PM
hwnd's Avatar
watashi no shichi
i did in fact; i'm going to give it another shot this weekend
Old Jul 27, 2007 | 06:43 PM
nyt's Avatar
nyt
in the wolf manual, which is no longer no the wolf site, it shows how to make a cable. I'll look thru the pdf i have and post it up in a few mins.
Old Jul 27, 2007 | 06:51 PM
nyt's Avatar
nyt
wow just looked thru installation, user guide, and pc software, and there was nothing (could have sworn there was), maybe it was a dealer tech.
edit: not in dealer tech either. If you cant get it to work with the diagram you found let me know and I'll check the pinouts on my cable
Old Jul 29, 2007 | 06:18 AM
Michael Smith's Avatar
https://www.rx7club.com/showthread.p...able+Version+4
Second post from George I built one from this
Cheers
MIchael Smith
Old Jul 30, 2007 | 04:24 PM
coxxoc's Avatar
Shooting for 500
I'm in the same position. With just an adapter, the Wolf shuts off when the PC is trying to connect. I guess I need to cut the DB15 and do that wiring.
Does anyone have a color coded version perhaps? It looks like that is showing the order from the back of the connector?
Old Jul 30, 2007 | 05:52 PM
coxxoc's Avatar
Shooting for 500
I made the adapter using a pinout in this post: https://www.rx7club.com/showthread.php?t=429560
The Wolf software (4.72) says it can find the ECU and retrieves the map. However, it pops up a box saying my map is missing the yellow and redlines and will default them to 8000 rpm. Then the ign and fuel tables are all zeros. When the laptop is plugged in, the car will not start. Unplug it, and everything is great.
I'd really like to use this computer to datalog, but I can't at the moment...
Does anyone know if this is something I've obviously messed up making the cable? Any other ideas would be welcome too.
Josh
Old Aug 2, 2007 | 05:49 AM
File Type: bmp
Old Aug 2, 2007 | 08:26 AM
signofinfinity's Avatar
Coyote
huh??? mine works great!!!!..... that is the soldering side of the connectors.... the shield if i remember correctly is attached to the outside of the connector....one per side...
Old Aug 2, 2007 | 10:34 PM
hwnd's Avatar
watashi no shichi
i bought another wolf v4 for the fd - with cable. couldn't wait to figure out whats wrong with the current one
Old Aug 3, 2007 | 07:31 AM
hwnd's Avatar
watashi no shichi
whats up with pin #9 on the 9pin side? looks like it was going somewhere ;]
Originally Posted by Michael Smith
Old Aug 3, 2007 | 02:54 PM
nyt's Avatar
nyt
9 is the one that isnt going anywhere. if you look you'll see the other pins on the DB9 side are connected to each other.
Old Aug 3, 2007 | 10:48 PM
Thats what happens when you flog a picture from somewhere else pin 9 is unconnected
Cheers
Michael Smith
toplessFC3Sman
Mar 20, 2018 01:54 PM
