MORE ?s: Low Power and fuel smell
Just put in a new rebuild. I haven't gotten on it yet (156 miles- never over 4k), but it seems like it doesn't have the low end torque of my last engine. It just seems slow......... I also smell strong fuel when i step on the gas. I guess it's running rich (at least it's not lean- i bet i shoot flames!!!) Anyway...
and suggestions or condolences
would be great. Do they get stronger with age? Or am i losing my mind and was my old engine that weak undr 4k. Mods listed below.....
Last thing, my clutch (rps carbon fiber twin disk) seems to be smoking a lot since I put in the new engine. Did it get adjusted wrongly? thanks again guys.
(when i say smoke, i mean i smell it burning.)
would be great. Do they get stronger with age? Or am i losing my mind and was my old engine that weak undr 4k. Mods listed below..... Last thing, my clutch (rps carbon fiber twin disk) seems to be smoking a lot since I put in the new engine. Did it get adjusted wrongly? thanks again guys.
When I first got my new streetported engine installed I thought I lost power too - but it was too much power - come to find out that my primary turbo doesn't work so that was my loss of low-end. I takes around 1000 miles for your engine to settle and break in. should change the oil at 500 miles. Does sound strange - might not be the actual engine but something minor.
Originally posted by EfiniX
watch your *** if you haven't had the fuel pulse regulator replaced!!!
Trending Topics
What about your fuel injectors? Are they perhaps leaking somehow? I would check those and the fuel pulsation dampener. I had a similar problem to you, although not nearly as bad: It ended up being the fuel pulsation dampener. I wouldn't drive your car until you get that fuel leak fixed, whatever it is.
Originally posted by rjuge
now i also think it may just be running rich. i don't see any fuel spray, just a smell.....
Just use the manual. It has steps on how to check the difference areas of it. Looks to be only about 3 check places so it shouldn't be too much of a PITA. As I said, I'll be doing it this coming weekend as well.
You will not be pulling full power bc of the new motor. I don't know if it is just a safety or what but mine was sluggish even at WOT until it broke in really good, 4k miles. Maybe it was just my car but I can feel the power now
i know a guy that had the fuel smell in his car too. he said that his gas cap was messed up and he replaced it and everything was gravy. i wish mine was that easy, i pulled off my uim, jumped the fp and grd terminals in the diag. box, turned the key on and watched a 3-4 inch fuel geyser errupt out of my fpd. i figured that out easily enough. hehe
alphawolff
Nov 17, 2015 05:57 PM
