Stupidity at it's best.
Old Apr 2, 2002 | 02:50 PM
Fingers's Avatar
Hey guys, i've been collecting some questions for quite some time... i figure if I ask them all at once, i could only get bashed once for being so stupid.
What is a crank case?
How do you distinguish between the leading coils and the trailing coils?
How do you distinguish between the leading plugs and the trailing plugs?
Where's the CPU?
Where's the ECU?
How long does it take to resolder the CPU joints?
On a scale of 1-10, how stupid am I?
Thanks!!
-Ross
Old Apr 2, 2002 | 02:52 PM
hybridracer's Avatar
I Post In The Nude
What model and year are you driving?
Old Apr 2, 2002 | 03:03 PM
Fingers's Avatar
My appologies. 1987 GXL
Old Apr 2, 2002 | 03:08 PM
I Post In The Nude
well if its the same as my 90 GTU then the leading coils are going to be near the front of the car, and the leading are going to be closer to the windsheild on the drivers side, then you can just follow the wires to find the leading and trailing sparks, im not sure about those. And sorry but i dunno about the rest of your questions im still kinda new to these.
Old Apr 2, 2002 | 03:09 PM
rico05's Avatar
WTB S5 N/A FC
There is no "crank case" on a rotary. We use it to relate parts on a rotary to those on a piston engine. The trailing coil is the ignitor on the innerfender on the driver's side, closest to the headlights. The leading, is closest to the driver. The CPU is located next to your right foot, on the driver's side. The ECU is located under the carpet, at the passenger's feet, under a protective panel. The resoldering sould take like 30 minutes, if you are good with a soldering iron. The best way to not feel so stupid, is to buy a Haynes manual, or go to www.fc3s,org, look under "Manuals" and download the factory serive manual!!
EDIT: THe trailing plugs are on top, the leading are on bottom. When you hold them in your hand, the trailing have a blue line on them, the leading plugs do not.
Old Apr 2, 2002 | 03:10 PM
Sniper_X's Avatar
**What is a crank case?
another term for a piston engine crankshaft area
**How do you distinguish between the leading coils and the trailing coils?
They are labeled. (L1 / L2) & (T1 / T2) on the coils
**How do you distinguish between the leading plugs and the trailing plugs?
They are labeled. (L / T)
**Where's the CPU?
Driver side at the left ankle area, just next to the dead pedal.
**Where's the ECU?
Passenger side at the top back of the foot area, Under a plate.
**How long does it take to resolder the CPU joints?
How long would it take you to glue 100 BBs to a 3x5 card?
**On a scale of 1-10, how stupid am I?
you can go from zero to hero in one night by downloading and reading this:
http://www.iluvmyrx7.com/Technical_I...ice_manual.htm
Sniper_X
Always Tinkering
Old Apr 2, 2002 | 03:16 PM
Fingers's Avatar
Cool cool. on a side note, I'm still on the Marvel Mystery oil. Where else does it go other than in the gas tank??
And the CPU... where is it located again? Under the dash?? Under the carpet?? Beside the stereo??
Old Apr 2, 2002 | 03:21 PM
rico05's Avatar
WTB S5 N/A FC
Right beside your riight foot. Pull back the carpet down there, and you will see it.
Old Apr 2, 2002 | 03:25 PM
ianbell's Avatar
I think you mean your other right foot?
Old Apr 2, 2002 | 03:34 PM
rico05's Avatar
WTB S5 N/A FC
OOPS!! The CPU is on the driver's side, next to your left foot when you are driving. Sorry for the mix up!!!
Old Apr 2, 2002 | 03:38 PM
Fingers's Avatar
Someone skipped too much classes in Grade 1
Old Apr 2, 2002 | 03:40 PM
Samps's Avatar
The leading coil is up front by the battery and the trailing is nearer to the driver. And they are marked with L1, L2.
Plugs go like dis:
T1 ----- T2
L1 ----- L2
Oh and; making an NA into a turbo is preaty hard and everything has been discussed before so you can find it in old posts.
You my freind are a bright enough individual to come out and ask a question. Stupid people are the ones who don't want to know.
Old Apr 2, 2002 | 03:41 PM
Josepi's Avatar
Despise Enmity
Sniper_X
Always Tinkering
I was thinking, what if you folded up the edges of the card, sprayed it with adhesive and poured the BBs in and got em all down. Let it dry, 25 minutes tops.
Old Apr 2, 2002 | 03:42 PM
Fingers's Avatar
Smart boy Josepi. I was thinking i'd use some 3M spray adhesive myself
Old Apr 3, 2002 | 07:26 PM
Sniper_X's Avatar
Thats exactly about the time it'll take!!!
Old Apr 3, 2002 | 07:54 PM
#1 -->
#2 -->
Someone is posting wrong information here.
According to the 88 shop manual, leading is by the headlight, trailing by the driver. (section 5-2)
Old Apr 3, 2002 | 08:43 PM
Sniper_X's Avatar
thats exactly what your second quote said too....
Im confuzed as to the point of posting the second quote.
Old Apr 3, 2002 | 09:03 PM
was just going to point out the two disagreeing points... but then thought I might as well do something more useful and look it up so I found it in the FSM and added what was there.
deconfuzed?
befarrer
15
May 19, 2022 10:44 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
