Sponsored by: CARiD
Start up smoke?
Old Jul 21, 2007 | 08:57 PM
ferrariyellowfd's Avatar
angry weed eater
Start up smoke?
My cars seals are not that old at all but the car is smoking on start up, and it's not the turbos ether, a mazda tech told me that there is a small oil tank thant lubes the intakewith oil to make sure the seals get lubed, and he said that there is a ajustment on this tank. have you guys herd about this? and if so where are the adjustments? thanks
Nyle
Old Jul 21, 2007 | 09:59 PM
-xlr8planet-'s Avatar
I has an emblem
quite off to be a mazda tech....
he was probably refering to the MOP (metering oil pump), but it draws oil from your oil pan.
What years is your car?
Old Jul 22, 2007 | 01:02 AM
angry weed eater
Sorry guys, It's a 1993 tt and if that is what he was talking about how would I adjust it?
Old Jul 22, 2007 | 02:11 PM
EricRyan's Avatar
Autocrossed. I got CONED!
I'd go ahead and say don't listen to the guy. A little smoke at startup is perfectly normal especially in colder climates.
How long does it smoke, how bad, what color, what does it smell like?
Old Jul 22, 2007 | 02:23 PM
angry weed eater
it's oil smoke, it just seems like a little more then it should, it smokes for about 3 minutes.
Old Jul 26, 2007 | 05:31 PM
angry weed eater
but does anyone know where this so called oil tank is, and how it could be adjusted?
Old Aug 11, 2007 | 08:13 AM
Barry Bordes's Avatar
"Elusive, not deceptive!”
The oil jets have a pocket that is actually designed to drain down after shut-down. This lubricates and helps compression for start-up. If they were dry you would get the dreaded high whine and no start till the plugs are removed and a squirt of oil is added to each rotor.
Barry
Old Sep 9, 2007 | 03:19 AM
rspeed9i6's Avatar
1308cc pure madness
hmmm leaky turbo maybe?
Old Sep 18, 2007 | 10:26 PM
needAgen3bad's Avatar
mine smokes for about 30 seconds at cold start up.. but if i let it run for a while... baby it for a while and then get on it.. it smokes a good amount... any reason why? fuel build up?? my car also says im running rich... ..... also...
i got break up at bout 6rpm... no i deal what the problem can be.. i dont have a scanner 2 hook up 2 it... i dont even know what kind of scanner i need.. i have a 93 touring... any help would be great... thanks...
Old Sep 28, 2007 | 03:21 AM
EricRyan's Avatar
needAgen3bad: Find your diagnostics box on the driver's side of your engine bay. Lift the cover, identify the terminals TEN and GND. Take a paper clip, short length of speaker wire....you get the idea, and bridge these two contacts together (with the key removed from the ignition of course). Get into your car and turn the key to the ON position, don't start it. If your car is throwing a code(s) it will flash them to you in morse code fashion.
Say you throw a code 55 for example, it will flash 5 long times and 5 short times shortly after. Do some research on the specific code(s) it's throwing and go from there.
As for startup smoke it is perfectly normal especially around 30 seconds long, and as for running rich how does your car tell you you're running "rich"?
Old Sep 29, 2007 | 04:32 PM
Has your engine ever had synthetic oil in it? On of the last ones that I repaired had Mobil One in it , it smoked and the side seal orings had shrunk. They fell out of the rotors as they were removed!
Barry
1987 T2
11
Apr 1, 2017 11:59 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
gabescanlon
Sep 5, 2015 12:09 AM
