S5 NA auto: starter fluid starts it then stays on BUT cannot self start!
Old Jul 16, 2007 | 09:51 PM
--MAstermind--'s Avatar
i was wondering if anyone knew anything about that? supposedly if ya spray starter fluid the FC starts, and runs... but it doesn't start without it...so I'm pretty confused on that....once it starts it goes through accelerated warm up and then holds 1k idle... its an auto.. i was just wondering if anyone knew what that could be?
things i KNOW
fuel pump checks ok
all vac lines check ok
has 135,XXXmiles
any pointers would be great!
thanks!!!
Old Jul 17, 2007 | 12:35 AM
RotaryResurrection's Avatar
bet you can't say the thread title 5 times fast.
Sounds like a weak compression engine that is flooding on startup. Auto's have a harder time getting started due to the extra mass of the torque convertor, pump, and fluid, and a borderline compression engine will just make this issue worse.
I have rebuilt MANY an s5 auto engine with 50-80k miles on the engine due to carbon buildup and weak compression that wouldn't let the car reliably restart.
Old Jul 17, 2007 | 04:05 AM
walken's Avatar
Registered Loser
fresh spark plugs sometimes help
Old Jul 17, 2007 | 07:12 PM
NoDOHC's Avatar
Automatic = Power drain
The start position coil in the fuel pump relay may be bad (requiring air flow to start.)
Thats my only guess other than poor compression.
Old Jul 18, 2007 | 03:29 PM
well thanks guys ill give her a compression test... i bit my tounge saying it ....ill keep ya guys posted...
where might this fuel pump relay be? the one under the dash? thanks for the help! ill also try the new plugs and see if.... i thought if it was flooeded though that the engine would only stay flooded due to MORE starter fluid.. either way all your comments are a great direction ill be back.....
Kyo
Apr 13, 2019 09:24 AM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
