car back fires
Old Jul 12, 2007 | 11:28 AM
bdrx-7's Avatar
car back fires
i got a 87 TII with turbo back exhaust and fcd. car has 82xxx and is stock besides those mods.
i did a tune up on it a couple days ago. plugs,wires fuel filter. i've been driving around is it ran great.
i went to start it up and it started up and then started to back fire and ****. i get on the highway to go to work and it backfires and won't go past 4k.
so i get home and adjust the tps to spec and it does better but still back fires and runs real rich. so i'm thinking leaky injector or mabe a ground issue.
Old Jul 12, 2007 | 01:01 PM
freemanrx7's Avatar
^Hold On
Are those the only mods you have? From my understanding you could have boost creep!. I mean that may not be the problem you have now but you should definetly look into porting the wastegate Try checking the compression on the rear rotor.
Old Jul 12, 2007 | 01:08 PM
boostedfc3s's Avatar
1.3 liter piston eater
+1 on the compression check. That's what mine did when I popped my engine. I had 25 PSI consistent on the front rotor and 0 PSI on the rear.
Old Jul 12, 2007 | 07:28 PM
bdrx-7's Avatar
those are the only mods. i didn't have boost creep unless my engine was cold and i wouldn't run it hard. i was going to port the WG next week. i was hoping it could wait til then.
it will start up and idle pretty good then when i give it gas and let off it backfires. when its warming up at idle it will backfire. i haven't had a chance to get a compression tester yet but i hope to get it this w/e. i hope it isn't blown but if it is o well its a rotary. i guess.
alphawolff
Nov 17, 2015 05:57 PM
zuesskroph
Aug 13, 2015 06:05 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
