fuel filter sludge oil. 2 stroke?
Old Jul 11, 2007 | 10:10 PM
initial D is REAL!'s Avatar
Hey guys, I changed my fuel filter today, and a lot of oil came out of it. Do you think that could have been some of the 2 stroke additive being caught in it along with the dirty stuff? Or is it just dirty stuff in the fuel?
Old Jul 11, 2007 | 11:56 PM
RETed's Avatar
What are you adding to your fuel?
-Ted
Old Jul 12, 2007 | 12:53 AM
Well, I never ran 2 sroke, but the guy that owned it before had added valvoline 2 stroke oil in it before I believe. He had put the omp back on to sell the car.
Old Jul 12, 2007 | 02:16 AM
RETed's Avatar
The stuff in the dark blue bottle?
It's not supposed to react with gasoline.
I use it in my FC.
-Ted
Old Jul 12, 2007 | 09:25 PM
I beleive so. he told me he ran 2 stroke oil for a little bit, I believe it was valvoline.
When I unhooked the fuel line, fuel came out, then after a while, some oil came out of there. Im guessing the fuel filter is catching the 2 stroke oil?
Old Jul 12, 2007 | 11:13 PM
immanuel__7's Avatar
interesting i all ways wondered if that would happen or if it could happen?? il have to pull mine off and see, im using Castrol GTX 2 cycle oil, but il pull mine off tomorrow and see if theres any oil stuck in there if so i guss we will have to buy snow machine fuel filters
Old Jul 12, 2007 | 11:55 PM
Yeah, I remmeber someone posting a quesiton ,"what fuel filter to use with 2 stroke?"
2 stroke additive is the only thing I could think of. So I guess that means not all the 2 stroke additive is getting to the engine. Unless that oil is something else.
The oil didnt look black or anything. It looked clean, but I could totally tell that it was not gasoline
Old Jul 13, 2007 | 12:53 AM
racerlinkfc's Avatar
which 2 stroke premix should i use?
hey i have the same question i have just been adding a lil bit of mobile non synthetic oil to my gas but i was reading on about the 2 stroke premix which one is better to use ?
Old Jul 13, 2007 | 06:59 AM
My5ABaby's Avatar
Rotaries confuse me
Wait, you've been adding regular (4 stroke) oil to your gas?
Old Jul 13, 2007 | 07:13 AM
pfsantos's Avatar
(blank)
I thought 2-stroke was supposed to become a homogeneous solution in fuel and not separate once dissolved? Can someone confirm this? I wonder if left mixed in a tank for long enough, if it settles to the bottom, causing what appears as stated.
Old Jul 13, 2007 | 08:15 AM
clokker's Avatar
Cake or Death?
If your fuel filter has sludge buildup I wonder what the sock on the fuel pump looks like.
Old Jul 13, 2007 | 01:59 PM
you cant use regular oil in your fuel tank, it just wont mix.
you have to use 2 stroke oil if you adding oil to you gas.
so premix 2 stroke oil is the only way to go if adding oil to your gas.
i have only ran 20$ of gas in my new filter so i hope to see if there is any oil or not in my filter. il post tonight and let you guys know
Old Jul 13, 2007 | 02:01 PM
if the sock is like a chev sock then id say it should be ok, cause it just stops big chunks its just a small screen, unlike the fuel filters they are paper filters if thats the correct terme to use
Old Jul 13, 2007 | 02:36 PM
1.3mazda's Avatar
HOT DOGS! 8======D
i read somewhere once that u could have like a resvorior full of 2 stroke oil and like a windsheild washer pump or something like that to shoot it into the oil metering nozzles???? but it defeintly bypassed the STOCK OMP
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
The1Sun
Mar 18, 2018 11:08 PM
HDA
Nov 3, 2015 03:49 PM
