Strange electrical problem
Old Jul 11, 2007 | 08:02 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
My car just recently developed an odd electrical issue
When it occures, i get intermenent power if any at all thoughout the car. i measured for example 2.5volts at my cig plug, 5volts in some fuses in the inside fuse box etc etc.
the batt is good, ive tried 3, all with the same result.
whats real odd, is the batt will still show 12v when this happens, the cables do not get hot, theres no odd smell, etc etc
once in a while (this last time) i loose power completly, no juice anywhere, after a few minuts i get power back?
It generaly happens when i try to start the car, however ive had it happen when i had the key on acc and simply turned on something else
Car is an 86 GXL, wolf3d with a comso re etc etc however the majority of the power distrabution harneses are unmolested, i ted in where apporpriate (stock fuel pump wiring powers my relay for my pump which pulles from my own fuse box, injectors pull from switched igntion from stock map sensor etc etc)
the car has been on the road for 3 years, nothing crazy worke don between the last times i drove it and now when this issue occured. im lost any idea's?
-Jacob
Old Jul 11, 2007 | 09:21 PM
1SxyRXy's Avatar
my fc broke
check chassis harness. check grounds. ive had a simliar problem with my 91 TII. i would randomly lost power to the lights at the cluster and weird stuff. after i did and engine it never happend again
Old Jul 12, 2007 | 10:37 AM
I had the same thing about 2 years ago and it dissapeared then too, however seem to be back to stay. Very confusing
Old Jul 12, 2007 | 08:53 PM
Old Jul 12, 2007 | 10:13 PM
c_k1881's Avatar
Newbie
Originally Posted by CrackHeadMel
I had nearly the same thing happen to me this week - wouldn't start, full electrical shutdown when turning the key to Start.
Turned out to be a loosened and quite corroded clamp on the lug on the the negative battery terminal - it's not the OEM lug, but one of those bolted clamp types. Cleaned and brushed everything (terminals, etc) reconnected and it started right up after that.
Might have gotten rid of some dash light dimming issues too, since the voltmeter isn't dipping like it used to but I only drove it for 5 minutes after the fix.. And it may just be me hoping the dimming is gone.
Hope it helps.
-C
Old Jul 12, 2007 | 10:44 PM
Toxindude's Avatar
I recently had this kinda problem I would go to start the car turn the key and nothing . Turned out I had a bad starter
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
firzen
Sep 15, 2015 12:04 PM
Monsterbox
Sep 11, 2015 03:29 PM
