What size is oil cooler line bolt????
Old Apr 1, 2002 | 02:30 PM
SPOautos's Avatar
Hey, where did my $$$ go?
Hey guys does anyone know what size the bolt is that bolts the oil cooler line to the motor??? Its very big, I went up to a 17mm (largest I had) and it wasnt even big enough. I'm going to buy a wrench but just want to make sure I get the right size first.
Any help is appreciated!!!!
Thanks,
STEPHEN
Old Apr 1, 2002 | 03:49 PM
CYM TKT's Avatar
hey, your car is on fire!
its 24 or 27 mm i think.. i just made this thread last week. search for it... u can use the quick disconnect connectors which is way easier
Old Apr 1, 2002 | 05:04 PM
SPOautos's Avatar
Yea, I saw that post but it never said what size the bolt is. I dont really need to remove mine. After a motor install a month or so ago there is a slow leak there. I just need to tighten it a little and I dont have anything that will fit it. I just need to know the right size so I can pick up a wrench on my way home from work
Thanks,
STEPHEN
Old Apr 2, 2002 | 10:55 AM
SPOautos's Avatar
bump
Old Apr 2, 2002 | 04:03 PM
SPOautos's Avatar
surely someone around here knows. I've heard its between 24mm and 27mm. Anyone know what size for sure???
Thanks,
STEPHEN
Old Apr 2, 2002 | 04:54 PM
FD Racer's Avatar
sold the FD...kept the FB
I just checked it out, unfortunately my wrench set skips from 22mm to 24mm. 22mm does not fit and 24mm is a bit loose. So I think it’s a 23mm, however it felt like 24mm would work if that were all you had.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
