drive shaft compatible?
Old Jul 10, 2007 | 01:34 AM
fc3schick87's Avatar
Rotary Addiction
ok well i threw on my tii rear end. and my tii engine is in with tii trani. i am using a tii drive shaft.
problem is. the diff has a bolt and some threading in the center that sits inside the drive shaft. and my drive shaft doesnt have a deep enough hole to hold the bolt with the threading.
the n/a drive shaft is deeper . the n/a diff has the same size bolt and same amount of threading on it that is to sit inside the drive shaft.
whats the problem? is s4 and s5 drive shafts different?
see the threading that is threw the bolt. well the drive shaft has a slot for it in the center of the hub. my hub wont sit flush because its to shallow,
Old Jul 10, 2007 | 02:08 AM
initial D is REAL!'s Avatar
Im a little new to this, but I thought s4 and s5 t2 driveshafts were the same. Are you sure you have a t2 driveshaft and diff?
Old Jul 10, 2007 | 02:16 AM
Rotary Addiction
of cource i am sure. if anything ..... the drive shaft is worng. but its deffinanlty the correct diff and half shafts
Old Jul 10, 2007 | 02:31 AM
mazdamigastos's Avatar
sounds like a na diff
Old Jul 10, 2007 | 02:35 AM
Rotary Addiction
oh so your not positive? or you are. does the tii diff have a shorter threading for the bolt? because this rear end is lsd. and its a little larger then the n/a one. the tii one is a different gearing ratio then the na
the na was 3:1
the tii was about 3.5:1 or some thing like that
Old Jul 10, 2007 | 02:37 AM
Rotary Addiction
the diff in the picture is an n/a diff.
Old Jul 10, 2007 | 11:19 AM
Rotary Addiction
bump!!!
Old Jul 10, 2007 | 01:53 PM
HAI-TEK7's Avatar
Check the driveshaft. See if the driveshaft mounting holes match up w/ the t2 diff mounting holes. The t2 diff flange has a bigger bolt pattern than n/a.
T2 driveshaft it beefier than an n/a.
Old Jul 10, 2007 | 02:28 PM
Boost or Bust's Avatar
Rotorhead in the making.
"the na was 3:1. the tii was about 3.5:1 or some thing like that"
Automatics have a 3.9, N/A's and Turbo II's have a 4.1 and the GTU's and Inifini have a 4.33.
Romeoxray7
Power FC Forum
15
Nov 20, 2015 01:38 AM
ptuttle
Aug 27, 2015 07:03 PM
