Bypass Heater Hose
Old Jul 9, 2007 | 11:34 AM
chaz9999's Avatar
Lonely Driver
Bypass Heater Hose
So I've got coolant leaking from (what it looks like) behind the firewall. I'm assuming that the heater hose that connects to the heater core is loose/damaged.
From what I've gathered in the Haynes manual, if I don't feel like getting to the heater core itself (removal of that involves going from the dash/console?) I could bypass it by connecting another heater hose,with a couple of male connectors, and the only thing I'd loose out on is no heat during winter right?
Thanks ahead of time for the response.
Old Jul 9, 2007 | 11:46 AM
freemanrx7's Avatar
^Hold On
Bought my 87 turbo set up that way. The hoses are zip tied to the A/C lines. Works for now! Damn thats a lot of work to replace that heater core
Old Jul 9, 2007 | 02:10 PM
chaz9999's Avatar
Lonely Driver
Thanks! Guess I'll do this until it gets too cold for me
Old Jul 9, 2007 | 11:53 PM
Omixeo's Avatar
'89 GTUs
Taking out the dash isn't hard at all, its worth it to have heat in the winter.
Old Jul 10, 2007 | 12:49 AM
arghx's Avatar
rotorhead
the only thing you'd lose is heat? even in Arizona it gets chilly...
Old Jul 19, 2007 | 12:45 AM
1st7's Avatar
no more 7
i just found out that i have that same problem as i turned on my AC to see if it blew at all and i pressed all the buttons but the temp didnt change.....the next day i was getting on the frreway and i noticed coolant leaking on my right foot as i accelerated ........how do i bypass the heater but i want to be able to use the AC......and where can i get a new heater core???
Old Jul 19, 2007 | 01:43 AM
Omixeo's Avatar
'89 GTUs
I have several sitting in a parts car if you want to buy one.
