Megasquirt megasquirt for a S5 TII
Old Jul 5, 2007 | 07:51 PM
FC3Sdrift's Avatar
Displacement Replacement
I'm thinking of just getting a megasquirt my S5TII swap into a S4 gx
My biggest concern is how do you guys control the oil metering pump
i really don't want to switch the front cover and back to a mechanical OMP
Do you just use the stock S4 main harness with the stock ecu controlling that
and the megasquirt connected to the engine harness controlling the actual engine functions
Old Jul 5, 2007 | 09:03 PM
T2GTUS's Avatar
s4's also use the mech omp ... there is no way ms can control the s5 omp ... go s4 front cover and omp ... or go premix ...
Old Jul 5, 2007 | 09:35 PM
FC3Sdrift's Avatar
thats the conclusion i've came to
does the S5 waterpump bolt to the S4 front cover?
Old Jul 5, 2007 | 09:49 PM
turboefini88's Avatar
Long rifle.
The water pump does not bolt to the front cover, just the front iron and yes, it will.
Old Jul 5, 2007 | 10:28 PM
FC3Sdrift's Avatar
How do i get a S5 TII engine to run in a S4 GX Chassis using Megasquirt n spark
harness wise....
i'm goin to let the stock S4 ecu control everything on the main harness
and the megasquirt run the fuel and spark ....should i use the S5 TII engine harness with the MSnS
what harnesses did you guys use?
Old Jul 5, 2007 | 10:45 PM
Long rifle.
Im using this http://www.glensgarage.com/catalog/u...port-p-77.html
You need to wire it into all the sensors/injectors/ect ect. The tach Im running from the signal off my trailing coil. If your gonna control spark and fuel, then there really is no need for the stock ECU to stay.
Old Jul 5, 2007 | 11:07 PM
FC3Sdrift's Avatar
i just want to make sure my speedometer will still work
Old Jul 5, 2007 | 11:15 PM
Long rifle.
Its mechanical. Runs off a cable from the tranny. Let me suggest you read, reread and reread again the megaquirt pages, not just here. I did it and it helped alot with understanding it all. Also, get an FSM and read up on how all the components work too before you go and get into a spot that your totally stuck in.
Good luck with your project and Im sure the MS gurus will be more then happy to help.
Old Jul 5, 2007 | 11:29 PM
FC3Sdrift's Avatar
i've spent weeks readin up on MS
i was goin to get one for my turbo set up on my KL-ZE turbo mx-3
long story short mx-3 was a victim of a hit and run
sold my turbo set up bought my rx-7 and motor
I didn't know it was a cable driven speedometer lol
i'm definately goin MSnSextra .... get my motor i with less hassle and get full use of the 4 extra injectors
thanks for your help
Sethix
Nov 3, 2017 11:48 PM
MidnightOwl
Sep 25, 2015 10:24 PM
