sway bars?
Old Jun 30, 2007 | 07:37 AM
Red_Rabbit86's Avatar
new to the rotary world
sway bars?
hey i was woudering if anybody know of a company that made a bigger sway bars then eibach and tanabe? they are about 22mm in front and 18mm in back give or take.
Old Jun 30, 2007 | 11:31 AM
Fault Bucket's Avatar
77333
Which gen? Eibachs for the FC are 28mm front, Tanabes are 27.5mm.
Old Jun 30, 2007 | 11:47 AM
VacavilleFC's Avatar
yeah stock t2 are 24 front and i believe 14mm rear
Old Jun 30, 2007 | 04:11 PM
Josh18_2k's Avatar
biggest ones i know of are suspension techniques.
Old Jun 30, 2007 | 06:53 PM
77333
Online info shows the ST front bar for the S4 is 28.5mm and the S5 front bar is 27. Their rear bar is 19mm though, which is bigger than the RB, Eibach or Tanabe rear bars (not that you'd really want a larger rear bar in most cases).
Old Jun 30, 2007 | 07:33 PM
elron90sc5speed's Avatar
Autocross'in fool.
Unless you like under steer.
Old Jul 1, 2007 | 07:48 AM
o i am just used to honda's and subie's where the stiffer the better. with my s4fc i am planing on drifting and i am just tired of the body roll so i thoughti would start basic. so which one whould you guy recomend st or tanabe (rear wise)?
Old Jul 1, 2007 | 12:11 PM
13bpower's Avatar
s4 for life
You can't real go wrong unless you mix and match different brands. A front and rear set were designed to work good together. As far a getting a good drift set up? Well not to many of us actually drift are cars on a regular basis. Only Angery Earl does that I know. He might chim in.
Old Jul 1, 2007 | 03:20 PM
Jerek10's Avatar
if you wanna drift. I BELIEVE you want the least amount of traction in the back, and the most in the front. which means the strongest **** in the back, and not so much in the front. massive springs and struts in the rear, swaybar etc. But yeah, you don't want to mix your component makes too drastically.
I'm no pro, I could be wrong, but, just some insight.
Old Jul 1, 2007 | 04:00 PM
Angry Earl's Avatar
Tall, Dark, & Handsome
Tanabe sways are great, and will most likely eliminate some/most of that body roll you speak of.
For drifting, like most other motorsports, you really want to have a balanced suspension setup...simply getting sways might satisfy your suspension desires on the short run, but saving up for fully adjustable coilovers (Stance's are niiiice), getting decent bushings (Prothane), DTSS rear toe eliminators, and subframe spacers (Uras, etc.), are things you'll really want to consider as you go along. You'll also eventually want some type of LSD (pref. a 2-way...Tomei, Cusco, Kaaz, etc.), you'll do a better job of getting both tires spinning.
haha, not to be too biased, but you can get most (if not all) of these things from
DRIFT OFFICE in Auburn, WA.
Their phone number is (253) 520-3888.
They're basically your one-stop shop for most/all of your drifting needs, and will most likely have anything and everything you need/want for your FC IN STOCK, ready for you to see, touch, and buy.
Tell them Earl sent you, and they'll take care of you.
Old Jul 1, 2007 | 04:50 PM
yeah i been to DO many times before i really like them. thanks for the insite guys
nycgps
30
Sep 29, 2015 12:02 AM
Jingkun
Sep 28, 2015 01:53 PM
