E Brake light won't turn off!
Old Mar 31, 2002 | 10:20 AM
Over this past winter I've been storing my car in my shed and just yesterday I went to check on it. Everything was fine except when I released the handbrake, the light on the dash wouldn't go out... Does anyone have any idea what I could do about this or what the problem is? thanks
Old Mar 31, 2002 | 10:39 AM
ponykiller's Avatar
You probably need to add brake fluid. The Ebrake light tells you two things:1)when the Ebrake is on. 2)when the brake fluid is low.
The brake resevoirs on 7s seem to leak a fair bit when the rubber gaskets below them wear out. Go replace them, but be warned that they are a pain to put back in (I had to clamp mine down overnight).
Kris
Old Mar 31, 2002 | 10:42 AM
Aaron Cake's Avatar
Engine, Not Motor
If it's not the brake fluid, there is a switch under the plastic cover on the E brake boot. It may be stuck, or out of adjustment.
Old Mar 31, 2002 | 10:49 AM
Flobb's Avatar
Rattle can retard
Check your brake fluid. If it's low, the light will be on. Or something could be making it think the brake is on when it's not. I've had what I assume was ice doing it to me. I'm guessing that because it went away the same time the snow did.
Old Mar 31, 2002 | 11:43 AM
Fingers's Avatar
yeah i have the same problem in my 7. The fluid is fine... the e-brake is down completely... it goes away after the car warms up, so i dont think its a big deal. The braking isnt affected at all.
Old Feb 4, 2004 | 10:01 PM
Tofuball's Avatar
Jesus is the Messiah
* Waves his hands to ressurect the thread from the dead * "ARISE!!!"
I'm having the same problem after the car has sit for 3 months and I swapped out the exhaust and differential.
Fluid is fine. Ebrake is fine.
Help!
Old Feb 4, 2004 | 10:53 PM
andrew lohaus's Avatar
um just make sure that the ebrake eraly is ok. i just thought my switch was bad, and it was for like 2 months, until it realy did end up engaging and destroying my rear brakes after about an hour on the hWY. it can be a costly mistake. dont blow this off you could regret it.
Old Feb 4, 2004 | 10:57 PM
sub9lulu's Avatar
my did the same
it happens when i take left hand corner at 35+mph .... weird ....
sometimes when its cold in the morning or something
Old Feb 4, 2004 | 11:28 PM
version13's Avatar
Exhaust leak
you may be turning your key too far from the on position when you start. check that.
Old Feb 4, 2004 | 11:34 PM
1SxyRXy's Avatar
my fc broke
while we're on brakes. my ABS light is on and i cleaned my sensors, checked the fuse and nothing. does the ABS light come on when you need to bleed the brakes?
diabolical1
30
Jan 30, 2016 05:50 AM
PhillyFC
Aug 21, 2015 06:36 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
